This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
retrieve()
The retrieve() method can be used to declare how to extract the response. For example:spring-doc.cn
WebClient client = WebClient.create("https://example.org");
Mono<ResponseEntity<Person>> result = client.get()
		.uri("/persons/{id}", id).accept(MediaType.APPLICATION_JSON)
		.retrieve()
		.toEntity(Person.class);
val client = WebClient.create("https://example.org")
val result = client.get()
		.retrieve()
		.toEntity<Person>().awaitSingle()
Or to get only the body:spring-doc.cn
Mono<Person> result = client.get()
		.retrieve()
		.bodyToMono(Person.class);
		.retrieve()
		.awaitBody<Person>()
To get a stream of decoded objects:spring-doc.cn
Flux<Quote> result = client.get()
		.uri("/quotes").accept(MediaType.TEXT_EVENT_STREAM)
		.retrieve()
		.bodyToFlux(Quote.class);
		.retrieve()
		.bodyToFlow<Quote>()
By default, 4xx or 5xx responses result in an WebClientResponseException, including sub-classes for specific HTTP status codes. To customize the handling of error responses, use onStatus handlers as follows:spring-doc.cn
		.retrieve()
		.onStatus(HttpStatusCode::is4xxClientError, response -> ...)
		.onStatus(HttpStatusCode::is5xxServerError, response -> ...)
		.retrieve()
		.onStatus(HttpStatusCode::is4xxClientError) { ... }
		.onStatus(HttpStatusCode::is5xxServerError) { ... }
