This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Plugging-in Different Back-end Caches
Clearly, there are plenty of caching products out there that you can use as a backing
store. For those that do not support JSR-107 you need to provide a CacheManager
and a
Cache
implementation. This may sound harder than it is, since, in practice, the classes
tend to be simple adapters that map the
caching abstraction framework on top of the storage API, as the Caffeine classes do.
Most CacheManager
classes can use the classes in the
org.springframework.cache.support
package (such as AbstractCacheManager
which takes
care of the boiler-plate code, leaving only the actual mapping to be completed).
