This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Attributes
You can add attributes to a request. This is convenient if you want to pass information through the filter chain and influence the behavior of filters for a given request. For example:
Java
Kotlin
WebClient client = WebClient.builder()
.filter((request, next) -> {
Optional<Object> usr = request.attribute("myAttribute");
client.get().uri("https://example.org/")
.attribute("myAttribute", "...")
.retrieve()
.bodyToMono(Void.class);
val client = WebClient.builder()
.filter { request, _ ->
val usr = request.attributes()["myAttribute"];
.build()
.retrieve()
.awaitBody<Unit>()
Note that you can configure a defaultRequest
callback globally at the
WebClient.Builder
level which lets you insert attributes into all requests,
which could be used for example in a Spring MVC application to populate
request attributes based on ThreadLocal
data.
