This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
WebSocket API
The Spring Framework provides a WebSocket API that you can use to write client- and server-side applications that handle WebSocket messages.
WebSocketHandler
Creating a WebSocket server is as simple as implementing WebSocketHandler
or, more
likely, extending either TextWebSocketHandler
or BinaryWebSocketHandler
. The following
example uses TextWebSocketHandler
import org.springframework.web.socket.WebSocketHandler;
import org.springframework.web.socket.WebSocketSession;
import org.springframework.web.socket.TextMessage;
public class MyHandler extends TextWebSocketHandler {
public void handleTextMessage(WebSocketSession session, TextMessage message) {
There is dedicated WebSocket Java configuration and XML namespace support for mapping the preceding WebSocket handler to a specific URL, as the following example shows:
import org.springframework.web.socket.config.annotation.EnableWebSocket;
import org.springframework.web.socket.config.annotation.WebSocketConfigurer;
import org.springframework.web.socket.config.annotation.WebSocketHandlerRegistry;
@EnableWebSocket
public class WebSocketConfig implements WebSocketConfigurer {
public void registerWebSocketHandlers(WebSocketHandlerRegistry registry) {
registry.addHandler(myHandler(), "/myHandler");
public WebSocketHandler myHandler() {
return new MyHandler();
The following example shows the XML configuration equivalent of the preceding example:
xmlns:websocket="http://www.springframework.org/schema/websocket"
xsi:schemaLocation="
https://www.springframework.org/schema/websocket/spring-websocket.xsd">
<websocket:handlers>
<websocket:mapping path="/myHandler" handler="myHandler"/>
</websocket:handlers>
<bean id="myHandler" class="org.springframework.samples.MyHandler"/>
</beans>
The preceding example is for use in Spring MVC applications and should be included
in the configuration of a DispatcherServlet
. However, Spring’s
WebSocket support does not depend on Spring MVC. It is relatively simple to
integrate a WebSocketHandler
into other HTTP-serving environments with the help of
WebSocketHttpRequestHandler
When using the WebSocketHandler
API directly vs indirectly, e.g. through the
STOMP messaging, the application must synchronize the sending of messages
since the underlying standard WebSocket session (JSR-356) does not allow concurrent
sending. One option is to wrap the WebSocketSession
with
ConcurrentWebSocketSessionDecorator
WebSocket Handshake
The easiest way to customize the initial HTTP WebSocket handshake request is through
a HandshakeInterceptor
, which exposes methods for “before” and “after” the handshake.
You can use such an interceptor to preclude the handshake or to make any attributes
available to the WebSocketSession
. The following example uses a built-in interceptor
to pass HTTP session attributes to the WebSocket session:
@EnableWebSocket
registry.addHandler(new MyHandler(), "/myHandler")
.addInterceptors(new HttpSessionHandshakeInterceptor());
<websocket:handshake-interceptors>
<bean class="org.springframework.web.socket.server.support.HttpSessionHandshakeInterceptor"/>
</websocket:handshake-interceptors>
</beans>
A more advanced option is to extend the DefaultHandshakeHandler
that performs
the steps of the WebSocket handshake, including validating the client origin,
negotiating a sub-protocol, and other details. An application may also need to use this
option if it needs to configure a custom RequestUpgradeStrategy
in order to
adapt to a WebSocket server engine and version that is not yet supported
(see Deployment for more on this subject).
Both the Java configuration and XML namespace make it possible to configure a custom
HandshakeHandler
Spring provides a WebSocketHandlerDecorator base class that you can use to decorate
a WebSocketHandler with additional behavior. Logging and exception handling
implementations are provided and added by default when using the WebSocket Java configuration
or XML namespace. The ExceptionWebSocketHandlerDecorator catches all uncaught
exceptions that arise from any WebSocketHandler method and closes the WebSocket
session with status 1011 , which indicates a server error.
Deployment
The Spring WebSocket API is easy to integrate into a Spring MVC application where
the DispatcherServlet
serves both HTTP WebSocket handshake and other
HTTP requests. It is also easy to integrate into other HTTP processing scenarios
by invoking WebSocketHttpRequestHandler
. This is convenient and easy to
understand. However, special considerations apply with regards to JSR-356 runtimes.
The Jakarta WebSocket API (JSR-356) provides two deployment mechanisms. The first
involves a Servlet container classpath scan (a Servlet 3 feature) at startup.
The other is a registration API to use at Servlet container initialization.
Neither of these mechanism makes it possible to use a single “front controller”
for all HTTP processing — including WebSocket handshake and all other HTTP
requests — such as Spring MVC’s DispatcherServlet
This is a significant limitation of JSR-356 that Spring’s WebSocket support addresses with
server-specific RequestUpgradeStrategy
implementations even when running in a JSR-356 runtime.
Such strategies currently exist for Tomcat, Jetty, GlassFish, WebLogic, WebSphere, and Undertow
(and WildFly). As of Jakarta WebSocket 2.1, a standard request upgrade strategy is available
which Spring chooses on Jakarta EE 10 based web containers such as Tomcat 10.1 and Jetty 12.
A secondary consideration is that Servlet containers with JSR-356 support are expected
to perform a ServletContainerInitializer
(SCI) scan that can slow down application
startup — in some cases, dramatically. If a significant impact is observed after an
upgrade to a Servlet container version with JSR-356 support, it should
be possible to selectively enable or disable web fragments (and SCI scanning)
through the use of the <absolute-ordering />
element in web.xml
<web-app xmlns="https://jakarta.ee/xml/ns/jakartaee"
https://jakarta.ee/xml/ns/jakartaee/web-app_5_0.xsd"
version="5.0">
<absolute-ordering/>
</web-app>
You can then selectively enable web fragments by name, such as Spring’s own
SpringServletContainerInitializer
that provides support for the Servlet 3
Java initialization API. The following example shows how to do so:
version="5.0">
<absolute-ordering>
<name>spring_web</name>
</absolute-ordering>
</web-app>
Configuring the Server
You can configure of the underlying WebSocket server such as input message buffer size, idle timeout, and more.
For Jakarta WebSocket servers, you can add a ServletServerContainerFactoryBean
to your
Java configuration. For example:
public ServletServerContainerFactoryBean createWebSocketContainer() {
ServletServerContainerFactoryBean container = new ServletServerContainerFactoryBean();
container.setMaxTextMessageBufferSize(8192);
container.setMaxBinaryMessageBufferSize(8192);
return container;
Or to your XML configuration:
<bean class="org.springframework...ServletServerContainerFactoryBean">
<property name="maxTextMessageBufferSize" value="8192"/>
<property name="maxBinaryMessageBufferSize" value="8192"/>
</bean>
</beans>
For client Jakarta WebSocket configuration, use
ContainerProvider.getWebSocketContainer() in Java configuration, or
WebSocketContainerFactoryBean in XML.
For Jetty, you can supply a Consumer
callback to configure the WebSocket server:
@EnableWebSocket
registry.addHandler(echoWebSocketHandler(), "/echo").setHandshakeHandler(handshakeHandler());
public DefaultHandshakeHandler handshakeHandler() {
JettyRequestUpgradeStrategy strategy = new JettyRequestUpgradeStrategy();
strategy.addWebSocketConfigurer(configurable -> {
policy.setInputBufferSize(8192);
policy.setIdleTimeout(600000);
return new DefaultHandshakeHandler(strategy);
When using STOMP over WebSocket, you will also need to configure STOMP WebSocket transport properties. |
Allowed Origins
As of Spring Framework 4.1.5, the default behavior for WebSocket and SockJS is to accept
only same-origin requests. It is also possible to allow all or a specified list of origins.
This check is mostly designed for browser clients. Nothing prevents other types
of clients from modifying the Origin
header value (see
RFC 6454: The Web Origin Concept for more details).
The three possible behaviors are:
Allow only same-origin requests (default): In this mode, when SockJS is enabled, the Iframe HTTP response header
X-Frame-Options
is set toSAMEORIGIN
, and JSONP transport is disabled, since it does not allow checking the origin of a request. As a consequence, IE6 and IE7 are not supported when this mode is enabled. -
Allow a specified list of origins: Each allowed origin must start with
http://
orhttps://
. In this mode, when SockJS is enabled, IFrame transport is disabled. As a consequence, IE6 through IE9 are not supported when this mode is enabled. -
Allow all origins: To enable this mode, you should provide
as the allowed origin value. In this mode, all transports are available.
You can configure WebSocket and SockJS allowed origins, as the following example shows:
@EnableWebSocket
registry.addHandler(myHandler(), "/myHandler").setAllowedOrigins("https://mydomain.com");
<websocket:handlers allowed-origins="https://mydomain.com">
<websocket:mapping path="/myHandler" handler="myHandler" />
</beans>
