This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Monitoring
When you use @EnableWebSocketMessageBroker
or <websocket:message-broker>
, key
infrastructure components automatically gather statistics and counters that provide
important insight into the internal state of the application. The configuration
also declares a bean of type WebSocketMessageBrokerStats
that gathers all
available information in one place and by default logs it at the INFO
level once
every 30 minutes. This bean can be exported to JMX through Spring’s
MBeanExporter
for viewing at runtime (for example, through JDK’s jconsole
The following list summarizes the available information:
- Client WebSocket Sessions
- Current
Indicates how many client sessions there are currently, with the count further broken down by WebSocket versus HTTP streaming and polling SockJS sessions.
- Total
Indicates how many total sessions have been established.
- Abnormally Closed
- Connect Failures
Sessions that got established but were closed after not having received any messages within 60 seconds. This is usually an indication of proxy or network issues.
- Send Limit Exceeded
Sessions closed after exceeding the configured send timeout or the send buffer limits, which can occur with slow clients (see previous section).
- Transport Errors
Sessions closed after a transport error, such as failure to read or write to a WebSocket connection or HTTP request or response.
- STOMP Frames
The total number of CONNECT, CONNECTED, and DISCONNECT frames processed, indicating how many clients connected on the STOMP level. Note that the DISCONNECT count may be lower when sessions get closed abnormally or when clients close without sending a DISCONNECT frame.
- STOMP Broker Relay
- TCP Connections
Indicates how many TCP connections on behalf of client WebSocket sessions are established to the broker. This should be equal to the number of client WebSocket sessions + 1 additional shared “system” connection for sending messages from within the application.
- STOMP Frames
The total number of CONNECT, CONNECTED, and DISCONNECT frames forwarded to or received from the broker on behalf of clients. Note that a DISCONNECT frame is sent to the broker regardless of how the client WebSocket session was closed. Therefore, a lower DISCONNECT frame count is an indication that the broker is pro-actively closing connections (maybe because of a heartbeat that did not arrive in time, an invalid input frame, or other issue).
- Client Inbound Channel
Statistics from the thread pool that backs the
clientInboundChannel
that provide insight into the health of incoming message processing. Tasks queueing up here is an indication that the application may be too slow to handle messages. If there I/O bound tasks (for example, slow database queries, HTTP requests to third party REST API, and so on), consider increasing the thread pool size. - Client Outbound Channel
clientOutboundChannel
that provides insight into the health of broadcasting messages to clients. Tasks queueing up here is an indication clients are too slow to consume messages. One way to address this is to increase the thread pool size to accommodate the expected number of concurrent slow clients. Another option is to reduce the send timeout and send buffer size limits (see the previous section). - SockJS Task Scheduler
Statistics from the thread pool of the SockJS task scheduler that is used to send heartbeats. Note that, when heartbeats are negotiated on the STOMP level, the SockJS heartbeats are disabled.
