This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
REST Clients
This section describes options for client-side access to REST endpoints.spring-doc.cn
RestClient
RestClient is a synchronous HTTP client that exposes a modern, fluent API.spring-doc.cn
See RestClient for more details.spring-doc.cn
WebClient
WebClient is a reactive client to perform HTTP requests with a fluent API.spring-doc.cn
See WebClient for more details.spring-doc.cn
RestTemplate
RestTemplate is a synchronous client to perform HTTP requests. It is the original Spring REST client and exposes a simple, template-method API over underlying HTTP client libraries.spring-doc.cn
See REST Endpoints for details.spring-doc.cn
HTTP Interface
The Spring Frameworks lets you define an HTTP service as a Java interface with HTTP exchange methods. You can then generate a proxy that implements this interface and performs the exchanges. This helps to simplify HTTP remote access and provides additional flexibility for to choose an API style such as synchronous or reactive.spring-doc.cn
