This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Configuration
The simplest way to create a WebClient
is through one of the static factory methods:
WebClient.create()
WebClient.create(String baseUrl)
You can also use WebClient.builder()
with further options:
uriBuilderFactory
: CustomizedUriBuilderFactory
to use as a base URL. -
defaultUriVariables
: default values to use when expanding URI templates. -
defaultHeader
: Headers for every request. -
defaultCookie
: Cookies for every request. -
defaultRequest
:Consumer
to customize every request. -
filter
: Client filter for every request. -
exchangeStrategies
: HTTP message reader/writer customizations. -
clientConnector
: HTTP client library settings. -
observationRegistry
: the registry to use for enabling Observability support. -
observationConvention
: an optional, custom convention to extract metadata for recorded observations.
For example:
Java
Kotlin
WebClient client = WebClient.builder()
.codecs(configurer -> ... )
val webClient = WebClient.builder()
.codecs { configurer -> ... }
.build()
Once built, a WebClient
is immutable. However, you can clone it and build a
modified copy as follows:
Java
Kotlin
WebClient client1 = WebClient.builder()
.filter(filterA).filter(filterB).build();
WebClient client2 = client1.mutate()
.filter(filterC).filter(filterD).build();
// client1 has filterA, filterB
// client2 has filterA, filterB, filterC, filterD
val client1 = WebClient.builder()
val client2 = client1.mutate()
MaxInMemorySize
Codecs have limits for buffering data in memory to avoid application memory issues. By default those are set to 256KB. If that’s not enough you’ll get the following error:
org.springframework.core.io.buffer.DataBufferLimitException: Exceeded limit on max bytes to buffer
To change the limit for default codecs, use the following:
Java
Kotlin
WebClient webClient = WebClient.builder()
.codecs(configurer -> configurer.defaultCodecs().maxInMemorySize(2 * 1024 * 1024))
.codecs { configurer -> configurer.defaultCodecs().maxInMemorySize(2 * 1024 * 1024) }
.build()
Reactor Netty
To customize Reactor Netty settings, provide a pre-configured HttpClient
Java
Kotlin
HttpClient httpClient = HttpClient.create().secure(sslSpec -> ...);
.clientConnector(new ReactorClientHttpConnector(httpClient))
val httpClient = HttpClient.create().secure { ... }
.clientConnector(ReactorClientHttpConnector(httpClient))
.build()
Resources
By default, HttpClient
participates in the global Reactor Netty resources held in
reactor.netty.http.HttpResources
, including event loop threads and a connection pool.
This is the recommended mode, since fixed, shared resources are preferred for event loop
concurrency. In this mode global resources remain active until the process exits.
If the server is timed with the process, there is typically no need for an explicit
shutdown. However, if the server can start or stop in-process (for example, a Spring MVC
application deployed as a WAR), you can declare a Spring-managed bean of type
ReactorResourceFactory
with globalResources=true
(the default) to ensure that the Reactor
Netty global resources are shut down when the Spring ApplicationContext
is closed,
as the following example shows:
Java
Kotlin
public ReactorResourceFactory reactorResourceFactory() {
return new ReactorResourceFactory();
fun reactorResourceFactory() = ReactorResourceFactory()
You can also choose not to participate in the global Reactor Netty resources. However, in this mode, the burden is on you to ensure that all Reactor Netty client and server instances use shared resources, as the following example shows:
Java
Kotlin
public ReactorResourceFactory resourceFactory() {
ReactorResourceFactory factory = new ReactorResourceFactory();
factory.setUseGlobalResources(false); (1)
return factory;
public WebClient webClient() {
Function<HttpClient, HttpClient> mapper = client -> {
// Further customizations...
ClientHttpConnector connector =
new ReactorClientHttpConnector(resourceFactory(), mapper); (2)
return WebClient.builder().clientConnector(connector).build(); (3)
1 | Create resources independent of global ones. |
2 | Use the ReactorClientHttpConnector constructor with resource factory. |
3 | Plug the connector into the WebClient.Builder . |
fun resourceFactory() = ReactorResourceFactory().apply {
isUseGlobalResources = false (1)
fun webClient(): WebClient {
val mapper: (HttpClient) -> HttpClient = {
val connector = ReactorClientHttpConnector(resourceFactory(), mapper) (2)
return WebClient.builder().clientConnector(connector).build() (3)
Timeouts
To configure a connection timeout:
Java
Kotlin
import io.netty.channel.ChannelOption;
.option(ChannelOption.CONNECT_TIMEOUT_MILLIS, 10000);
To configure a read or write timeout:
Java
Kotlin
import io.netty.handler.timeout.ReadTimeoutHandler;
import io.netty.handler.timeout.WriteTimeoutHandler;
.doOnConnected(conn -> conn
.addHandlerLast(new ReadTimeoutHandler(10))
.addHandlerLast(new WriteTimeoutHandler(10)));
// Create WebClient...
.doOnConnected { conn -> conn
.addHandlerLast(ReadTimeoutHandler(10))
.addHandlerLast(WriteTimeoutHandler(10))
To configure a response timeout for all requests:
Java
Kotlin
.responseTimeout(Duration.ofSeconds(2));
To configure a response timeout for a specific request:
Java
Kotlin
WebClient.create().get()
.uri("https://example.org/path")
.httpRequest(httpRequest -> {
HttpClientRequest reactorRequest = httpRequest.getNativeRequest();
reactorRequest.responseTimeout(Duration.ofSeconds(2));
.retrieve()
.bodyToMono(String.class);
.httpRequest { httpRequest: ClientHttpRequest ->
val reactorRequest = httpRequest.getNativeRequest<HttpClientRequest>()
.retrieve()
.bodyToMono(String::class.java)
JDK HttpClient
The following example shows how to customize the JDK HttpClient
Java
Kotlin
HttpClient httpClient = HttpClient.newBuilder()
.followRedirects(Redirect.NORMAL)
.connectTimeout(Duration.ofSeconds(20))
new JdkClientHttpConnector(httpClient, new DefaultDataBufferFactory());
WebClient webClient = WebClient.builder().clientConnector(connector).build();
val httpClient = HttpClient.newBuilder()
.build()
val connector = JdkClientHttpConnector(httpClient, DefaultDataBufferFactory())
val webClient = WebClient.builder().clientConnector(connector).build()
Jetty
The following example shows how to customize Jetty HttpClient
settings:
Java
Kotlin
HttpClient httpClient = new HttpClient();
httpClient.setCookieStore(...);
.clientConnector(new JettyClientHttpConnector(httpClient))
val httpClient = HttpClient()
httpClient.cookieStore = ...
.clientConnector(JettyClientHttpConnector(httpClient))
creates its own resources (Executor
, ByteBufferPool
, Scheduler
which remain active until the process exits or stop()
is called.
You can share resources between multiple instances of the Jetty client (and server) and
ensure that the resources are shut down when the Spring ApplicationContext
is closed by
declaring a Spring-managed bean of type JettyResourceFactory
shows:
Java
Kotlin
public JettyResourceFactory resourceFactory() {
return new JettyResourceFactory();
new JettyClientHttpConnector(httpClient, resourceFactory()); (1)
return WebClient.builder().clientConnector(connector).build(); (2)
1 | Use the JettyClientHttpConnector constructor with resource factory. |
2 | Plug the connector into the WebClient.Builder . |
fun resourceFactory() = JettyResourceFactory()
val connector = JettyClientHttpConnector(httpClient, resourceFactory()) (1)
return WebClient.builder().clientConnector(connector).build() (2)
HttpComponents
The following example shows how to customize Apache HttpComponents HttpClient
settings:
Java
Kotlin
HttpAsyncClientBuilder clientBuilder = HttpAsyncClients.custom();
clientBuilder.setDefaultRequestConfig(...);
CloseableHttpAsyncClient client = clientBuilder.build();
ClientHttpConnector connector = new HttpComponentsClientHttpConnector(client);
val client = HttpAsyncClients.custom().apply {
}.build()
val connector = HttpComponentsClientHttpConnector(client)
