This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Fine-tuning Annotation-based Autowiring with @Primary
Because autowiring by type may lead to multiple candidates, it is often necessary to have
more control over the selection process. One way to accomplish this is with Spring’s
@Primary
annotation. @Primary
indicates that a particular bean should be given
preference when multiple beans are candidates to be autowired to a single-valued
dependency. If exactly one primary bean exists among the candidates, it becomes the
autowired value.
Consider the following configuration that defines firstMovieCatalog
as the
primary MovieCatalog
Java
Kotlin
public class MovieConfiguration {
@Primary
public MovieCatalog firstMovieCatalog() { ... }
public MovieCatalog secondMovieCatalog() { ... }
@Primary
fun firstMovieCatalog(): MovieCatalog { ... }
fun secondMovieCatalog(): MovieCatalog { ... }
With the preceding configuration, the following MovieRecommender
is autowired with the
firstMovieCatalog
Java
Kotlin
public class MovieRecommender {
@Autowired
private MovieCatalog movieCatalog;
@Autowired
private lateinit var movieCatalog: MovieCatalog
The corresponding bean definitions follow:
xmlns:context="http://www.springframework.org/schema/context"
https://www.springframework.org/schema/context/spring-context.xsd">
<context:annotation-config/>
<bean class="example.SimpleMovieCatalog" primary="true">
<!-- inject any dependencies required by this bean -->
</bean>
<bean class="example.SimpleMovieCatalog">
</bean>
<bean id="movieRecommender" class="example.MovieRecommender"/>
</beans>
