This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Parallel Test Execution
Spring Framework 5.0 introduced basic support for executing tests in parallel within a single JVM when using the Spring TestContext Framework. In general, this means that most test classes or test methods can be run in parallel without any changes to test code or configuration.
For details on how to set up parallel test execution, see the documentation for your testing framework, build tool, or IDE. |
Keep in mind that the introduction of concurrency into your test suite can result in unexpected side effects, strange runtime behavior, and tests that fail intermittently or seemingly randomly. The Spring Team therefore provides the following general guidelines for when not to run tests in parallel.
Do not run tests in parallel if the tests:
Use Spring Framework’s
@DirtiesContext
support. -
Use Spring Boot’s
@MockBean
or@SpyBean
support. -
Use JUnit 4’s
@FixMethodOrder
support or any testing framework feature that is designed to ensure that test methods run in a particular order. Note, however, that this does not apply if entire test classes are run in parallel. -
Change the state of shared services or systems such as a database, message broker, filesystem, and others. This applies to both embedded and external systems.
If parallel test execution fails with an exception stating that the This may be due to the use of |
Parallel test execution in the Spring TestContext Framework is only possible if
the underlying TestContext implementation provides a copy constructor, as explained in
the javadoc for TestContext . The
DefaultTestContext used in Spring provides such a constructor. However, if you use a
third-party library that provides a custom TestContext implementation, you need to
verify that it is suitable for parallel test execution.
