This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Operators
The Spring Expression Language supports the following kinds of operators:
Relational Operators
The relational operators (equal, not equal, less than, less than or equal, greater than,
and greater than or equal) are supported by using standard operator notation.
These operators work on Number
types as well as types implementing Comparable
The following listing shows a few examples of relational operators:
Java
Kotlin
// evaluates to true
boolean trueValue = parser.parseExpression("2 == 2").getValue(Boolean.class);
// evaluates to false
boolean falseValue = parser.parseExpression("2 < -5.0").getValue(Boolean.class);
boolean trueValue = parser.parseExpression("'black' < 'block'").getValue(Boolean.class);
// uses CustomValue:::compareTo
boolean trueValue = parser.parseExpression("new CustomValue(1) < new CustomValue(2)").getValue(Boolean.class);
val trueValue = parser.parseExpression("2 == 2").getValue(Boolean::class.java)
val falseValue = parser.parseExpression("2 < -5.0").getValue(Boolean::class.java)
val trueValue = parser.parseExpression("'black' < 'block'").getValue(Boolean::class.java)
val trueValue = parser.parseExpression("new CustomValue(1) < new CustomValue(2)").getValue(Boolean::class.java);
Greater-than and less-than comparisons against If you prefer numeric comparisons instead, avoid number-based |
Each symbolic operator can also be specified as a purely textual equivalent. This avoids problems where the symbols used have special meaning for the document type in which the expression is embedded (such as in an XML document). The textual equivalents are:
lt
gt
le
ge
eq
ne
All of the textual operators are case-insensitive.
In addition to the standard relational operators, SpEL supports the between
instanceof
, and regular expression-based matches
operators. The following listing
shows examples of all three:
Java
Kotlin
boolean result;
result = parser.parseExpression(
"1 between {1, 5}").getValue(Boolean.class);
"1 between {10, 15}").getValue(Boolean.class);
"'elephant' between {'aardvark', 'zebra'}").getValue(Boolean.class);
"'elephant' between {'aardvark', 'cobra'}").getValue(Boolean.class);
"123 instanceof T(Integer)").getValue(Boolean.class);
"'xyz' instanceof T(Integer)").getValue(Boolean.class);
"'5.00' matches '^-?\\d+(\\.\\d{2})?$'").getValue(Boolean.class);
"'5.0067' matches '^-?\\d+(\\.\\d{2})?$'").getValue(Boolean.class);
var result = parser.parseExpression(
"1 between {1, 5}").getValue(Boolean::class.java)
"1 between {10, 15}").getValue(Boolean::class.java)
"'elephant' between {'aardvark', 'zebra'}").getValue(Boolean::class.java)
"'elephant' between {'aardvark', 'cobra'}").getValue(Boolean::class.java)
"123 instanceof T(Integer)").getValue(Boolean::class.java)
"'xyz' instanceof T(Integer)").getValue(Boolean::class.java)
"'5.00' matches '^-?\\d+(\\.\\d{2})?$'").getValue(Boolean::class.java)
"'5.0067' matches '^-?\\d+(\\.\\d{2})?$'").getValue(Boolean::class.java)
The syntax for the Consequently, |
Be careful with primitive types, as they are immediately boxed up to their
wrapper types. For example, 1 instanceof T(int) evaluates to false , while
1 instanceof T(Integer) evaluates to true .
Logical Operators
SpEL supports the following logical (boolean
) operators:
and
or
not
The following example shows how to use the logical operators:
Java
Kotlin
// -- AND --
boolean falseValue = parser.parseExpression("true and false").getValue(Boolean.class);
String expression = "isMember('Nikola Tesla') and isMember('Mihajlo Pupin')";
boolean trueValue = parser.parseExpression(expression).getValue(societyContext, Boolean.class);
// -- OR --
boolean trueValue = parser.parseExpression("true or false").getValue(Boolean.class);
String expression = "isMember('Nikola Tesla') or isMember('Albert Einstein')";
// -- NOT --
boolean falseValue = parser.parseExpression("!true").getValue(Boolean.class);
// -- AND and NOT --
String expression = "isMember('Nikola Tesla') and !isMember('Mihajlo Pupin')";
boolean falseValue = parser.parseExpression(expression).getValue(societyContext, Boolean.class);
// -- AND --
val falseValue = parser.parseExpression("true and false").getValue(Boolean::class.java)
val expression = "isMember('Nikola Tesla') and isMember('Mihajlo Pupin')"
val trueValue = parser.parseExpression(expression).getValue(societyContext, Boolean::class.java)
// -- OR --
val trueValue = parser.parseExpression("true or false").getValue(Boolean::class.java)
val expression = "isMember('Nikola Tesla') or isMember('Albert Einstein')"
// -- NOT --
val falseValue = parser.parseExpression("!true").getValue(Boolean::class.java)
val expression = "isMember('Nikola Tesla') and !isMember('Mihajlo Pupin')"
val falseValue = parser.parseExpression(expression).getValue(societyContext, Boolean::class.java)
String Operators
You can use the following operators on strings.
concatenation (
subtraction (
for use with a string containing a single character
repeat (
The following example shows the String
operators in use:
Java
Kotlin
// -- Concatenation --
// evaluates to "hello world"
String helloWorld = parser.parseExpression("'hello' + ' ' + 'world'")
.getValue(String.class);
// -- Character Subtraction --
// evaluates to 'a'
char ch = parser.parseExpression("'d' - 3")
.getValue(char.class);
// -- Repeat --
// evaluates to "abcabc"
String repeated = parser.parseExpression("'abc' * 2")
val helloWorld = parser.parseExpression("'hello' + ' ' + 'world'")
.getValue(String::class.java)
// evaluates to 'a'
val ch = parser.parseExpression("'d' - 3")
.getValue(Character::class.java);
// -- Repeat --
val repeated = parser.parseExpression("'abc' * 2")
.getValue(String::class.java);
Mathematical Operators
You can use the following operators on numbers, and standard operator precedence is enforced.
addition (
subtraction (
increment (
decrement (
multiplication (
division (
modulus (
exponential power (
The division and modulus operators can also be specified as a purely textual equivalent. This avoids problems where the symbols used have special meaning for the document type in which the expression is embedded (such as in an XML document). The textual equivalents are:
div
mod
The increment and decrement operators can be used with either prefix ( |
The following example shows the mathematical operators in use:
Java
Kotlin
Inventor inventor = new Inventor();
EvaluationContext context = SimpleEvaluationContext.forReadWriteDataBinding().build();
// -- Addition --
int two = parser.parseExpression("1 + 1").getValue(int.class); // 2
// -- Subtraction --
int four = parser.parseExpression("1 - -3").getValue(int.class); // 4
double d = parser.parseExpression("1000.00 - 1e4").getValue(double.class); // -9000
// -- Increment --
// The counter property in Inventor has an initial value of 0.
// evaluates to 2; counter is now 1
two = parser.parseExpression("counter++ + 2").getValue(context, inventor, int.class);
// evaluates to 5; counter is now 2
int five = parser.parseExpression("3 + ++counter").getValue(context, inventor, int.class);
// -- Decrement --
// The counter property in Inventor has a value of 2.
// evaluates to 6; counter is now 1
int six = parser.parseExpression("counter-- + 4").getValue(context, inventor, int.class);
// evaluates to 5; counter is now 0
five = parser.parseExpression("5 + --counter").getValue(context, inventor, int.class);
// -- Multiplication --
six = parser.parseExpression("-2 * -3").getValue(int.class); // 6
double twentyFour = parser.parseExpression("2.0 * 3e0 * 4").getValue(double.class); // 24.0
// -- Division --
int minusTwo = parser.parseExpression("6 / -3").getValue(int.class); // -2
double one = parser.parseExpression("8.0 / 4e0 / 2").getValue(double.class); // 1.0
// -- Modulus --
int three = parser.parseExpression("7 % 4").getValue(int.class); // 3
int oneInt = parser.parseExpression("8 / 5 % 2").getValue(int.class); // 1
// -- Exponential power --
int maxInt = parser.parseExpression("(2^31) - 1").getValue(int.class); // Integer.MAX_VALUE
int minInt = parser.parseExpression("-2^31").getValue(int.class); // Integer.MIN_VALUE
// -- Operator precedence --
int minusTwentyOne = parser.parseExpression("1+2-3*8").getValue(int.class); // -21
val inventor = Inventor()
val context = SimpleEvaluationContext.forReadWriteDataBinding().build()
// -- Addition --
var two = parser.parseExpression("1 + 1").getValue(Int::class.java) // 2
val four = parser.parseExpression("1 - -3").getValue(Int::class.java) // 4
val d = parser.parseExpression("1000.00 - 1e4").getValue(Double::class.java) // -9000
// -- Increment --
two = parser.parseExpression("counter++ + 2").getValue(context, inventor, Int::class.java)
var five = parser.parseExpression("3 + ++counter").getValue(context, inventor, Int::class.java)
// -- Decrement --
var six = parser.parseExpression("counter-- + 4").getValue(context, inventor, Int::class.java)
five = parser.parseExpression("5 + --counter").getValue(context, inventor, Int::class.java)
six = parser.parseExpression("-2 * -3").getValue(Int::class.java) // 6
val twentyFour = parser.parseExpression("2.0 * 3e0 * 4").getValue(Double::class.java) // 24.0
// -- Division --
val minusTwo = parser.parseExpression("6 / -3").getValue(Int::class.java) // -2
val one = parser.parseExpression("8.0 / 4e0 / 2").getValue(Double::class.java) // 1.0
// -- Modulus --
val three = parser.parseExpression("7 % 4").getValue(Int::class.java) // 3
val oneInt = parser.parseExpression("8 / 5 % 2").getValue(Int::class.java) // 1
val maxInt = parser.parseExpression("(2^31) - 1").getValue(Int::class.java) // Integer.MAX_VALUE
val minInt = parser.parseExpression("-2^31").getValue(Int::class.java) // Integer.MIN_VALUE
val minusTwentyOne = parser.parseExpression("1+2-3*8").getValue(Int::class.java) // -21
The Assignment Operator
To set a property, use the assignment operator (=
). This is typically done within a
call to setValue
but can also be done inside a call to getValue
. The following
listing shows both ways to use the assignment operator:
Java
Kotlin
parser.parseExpression("name").setValue(context, inventor, "Aleksandar Seovic");
// alternatively
String aleks = parser.parseExpression(
"name = 'Aleksandar Seovic'").getValue(context, inventor, String.class);
// alternatively
val aleks = parser.parseExpression(
"name = 'Aleksandar Seovic'").getValue(context, inventor, String::class.java)
Overloaded Operators
By default, the mathematical operations defined in SpEL’s Operation
enum (ADD
SUBTRACT
, DIVIDE
, MULTIPLY
, MODULUS
, and POWER
) support simple types like
numbers. By providing an implementation of OperatorOverloader
, the expression language
can support these operations on other types.
For example, if we want to overload the ADD
operator to allow two lists to be
concatenated using the +
sign, we can implement a custom OperatorOverloader
as
follows.
pubic class ListConcatenation implements OperatorOverloader {
public boolean overridesOperation(Operation operation, Object left, Object right) {
return (operation == Operation.ADD &&
left instanceof List && right instanceof List);
public Object operate(Operation operation, Object left, Object right) {
if (operation == Operation.ADD &&
left instanceof List list1 && right instanceof List list2) {
List result = new ArrayList(list1);
result.addAll(list2);
return result;
throw new UnsupportedOperationException(
"No overload for operation %s and operands [%s] and [%s]"
.formatted(operation, left, right));
If we register ListConcatenation
as the OperatorOverloader
in a
StandardEvaluationContext
, we can then evaluate expressions like {1, 2, 3} + {4, 5}
as demonstrated in the following example.
Java
Kotlin
StandardEvaluationContext context = new StandardEvaluationContext();
context.setOperatorOverloader(new ListConcatenation());
// evaluates to a new list: [1, 2, 3, 4, 5]
parser.parseExpression("{1, 2, 3} + {2 + 2, 5}").getValue(context, List.class);
StandardEvaluationContext context = StandardEvaluationContext()
context.setOperatorOverloader(ListConcatenation())
parser.parseExpression("{1, 2, 3} + {2 + 2, 5}").getValue(context, List::class.java)
An |
Any expression that uses an overloaded operator cannot be compiled. See Compiler Limitations for details. |
