This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Filters
The spring-web
module provides some useful filters:
Form Data
Browsers can submit form data only through HTTP GET or HTTP POST but non-browser clients can also
use HTTP PUT, PATCH, and DELETE. The Servlet API requires ServletRequest.getParameter*()
methods to support form field access only for HTTP POST.
The spring-web
module provides FormContentFilter
to intercept HTTP PUT, PATCH, and DELETE
requests with a content type of application/x-www-form-urlencoded
, read the form data from
the body of the request, and wrap the ServletRequest
to make the form data
available through the ServletRequest.getParameter*()
family of methods.
Forwarded Headers
As a request goes through proxies such as load balancers the host, port, and scheme may change, and that makes it a challenge to create links that point to the correct host, port, and scheme from a client perspective.
RFC 7239 defines the Forwarded
HTTP header
that proxies can use to provide information about the original request.
Non-standard Headers
There are other non-standard headers, too, including X-Forwarded-Host
, X-Forwarded-Port
X-Forwarded-Proto
, X-Forwarded-Ssl
, and X-Forwarded-Prefix
X-Forwarded-Host
While not standard, X-Forwarded-Host: <host>
is a de-facto standard header that is used to communicate the original host to a
downstream server. For example, if a request of example.com/resource
is sent to
a proxy which forwards the request to localhost:8080/resource
, then a header of
X-Forwarded-Host: example.com
can be sent to inform the server that the original host was example.com
X-Forwarded-Port
While not standard, X-Forwarded-Port: <port>
communicate the original port to a downstream server. For example, if a request of
is sent to a proxy which forwards the request to
, then a header of X-Forwarded-Port: 443
can be sent
to inform the server that the original port was 443
X-Forwarded-Proto
While not standard, X-Forwarded-Proto: (https|http)
is a de-facto standard header that is used to communicate the original protocol (e.g. https / https)
to a downstream server. For example, if a request of example.com/resource
is sent to
, then a header of
X-Forwarded-Proto: https
can be sent to inform the server that the original protocol was https
X-Forwarded-Ssl
While not standard, X-Forwarded-Ssl: (on|off)
original protocol (e.g. https / https) to a downstream server. For example, if a request of
, then a header of X-Forwarded-Ssl: on
X-Forwarded-Prefix
While not standard, X-Forwarded-Prefix: <prefix>
is a de-facto standard header that is used to communicate the original URL path prefix to a
downstream server.
Use of X-Forwarded-Prefix
can vary by deployment scenario, and needs to be flexible to
allow replacing, removing, or prepending the path prefix of the target server.
Scenario 1: Override path prefix
https://example.com/api/{path} -> http://localhost:8080/app1/{path}
The prefix is the start of the path before the capture group {path}
. For the proxy,
the prefix is /api
while for the server the prefix is /app1
. In this case, the proxy
can send X-Forwarded-Prefix: /api
to have the original prefix /api
override the
server prefix /app1
Scenario 2: Remove path prefix
At times, an application may want to have the prefix removed. For example, consider the following proxy to server mapping:
https://app1.example.com/{path} -> http://localhost:8080/app1/{path} https://app2.example.com/{path} -> http://localhost:8080/app2/{path}
The proxy has no prefix, while applications app1
and app2
have path prefixes
/app1
and /app2
respectively. The proxy can send X-Forwarded-Prefix:
to
have the empty prefix override server prefixes /app1
and /app2
A common case for this deployment scenario is where licenses are paid per production application server, and it is preferable to deploy multiple applications per server to reduce fees. Another reason is to run more applications on the same server in order to share the resources required by the server to run. In these scenarios, applications need a non-empty context root because there are multiple applications on the same server. However, this should not be visible in URL paths of the public API where applications may use different subdomains that provides benefits such as:
Scenario 3: Insert path prefix
In other cases, it may be necessary to prepend a prefix. For example, consider the following proxy to server mapping:
https://example.com/api/app1/{path} -> http://localhost:8080/app1/{path}
In this case, the proxy has a prefix of /api/app1
and the server has a prefix of
/app1
. The proxy can send X-Forwarded-Prefix: /api/app1
/api/app1
override the server prefix /app1
ForwardedHeaderFilter
is a Servlet filter that modifies the request in order to
a) change the host, port, and scheme based on Forwarded
headers, and b) to remove those
headers to eliminate further impact. The filter relies on wrapping the request, and
therefore it must be ordered ahead of other filters, such as RequestContextFilter
, that
should work with the modified and not the original request.
Security Considerations
There are security considerations for forwarded headers since an application cannot know
if the headers were added by a proxy, as intended, or by a malicious client. This is why
a proxy at the boundary of trust should be configured to remove untrusted Forwarded
headers that come from the outside. You can also configure the ForwardedHeaderFilter
with removeOnly=true
, in which case it removes but does not use the headers.
Dispatcher Types
In order to support asynchronous requests and error dispatches this
filter should be mapped with DispatcherType.ASYNC
and also DispatcherType.ERROR
If using Spring Framework’s AbstractAnnotationConfigDispatcherServletInitializer
(see Servlet Config) all filters are automatically registered for all dispatch
types. However if registering the filter via web.xml
or in Spring Boot via a
FilterRegistrationBean
be sure to include DispatcherType.ASYNC
and
in addition to DispatcherType.REQUEST
Shallow ETag
The ShallowEtagHeaderFilter
filter creates a “shallow” ETag by caching the content
written to the response and computing an MD5 hash from it. The next time a client sends,
it does the same, but it also compares the computed value against the If-None-Match
request header and, if the two are equal, returns a 304 (NOT_MODIFIED).
This strategy saves network bandwidth but not CPU, as the full response must be computed for each request.
State-changing HTTP methods and other HTTP conditional request headers such as If-Match
and
If-Unmodified-Since
are outside the scope of this filter. Other strategies at the controller level
can avoid the computation and have a broader support for HTTP conditional requests.
See HTTP Caching.
This filter has a writeWeakETag
parameter that configures the filter to write weak ETags
similar to the following: W/"02a2d595e6ed9a0b24f027f2b63b134d6"
(as defined in
RFC 7232 Section 2.3).
In order to support asynchronous requests this filter must be mapped
so that the filter can delay and successfully generate an
ETag to the end of the last async dispatch. If using Spring Framework’s
all filters are automatically registered for all dispatch types. However if registering
or in Spring Boot via a FilterRegistrationBean
be sure to include
CORS
Spring MVC provides fine-grained support for CORS configuration through annotations on
controllers. However, when used with Spring Security, we advise relying on the built-in
CorsFilter
that must be ordered ahead of Spring Security’s chain of filters.
See the sections on CORS and the CORS Filter for more details.
