This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Context Configuration with XML resources
To load an ApplicationContext
for your tests by using XML configuration files, annotate
your test class with @ContextConfiguration
and configure the locations
attribute with
an array that contains the resource locations of XML configuration metadata. A plain or
relative path (for example, context.xml
) is treated as a classpath resource that is
relative to the package in which the test class is defined. A path starting with a slash
is treated as an absolute classpath location (for example, /org/example/config.xml
). A
path that represents a resource URL (i.e., a path prefixed with classpath:
, file:
http:
, etc.) is used as is.
Java
Kotlin
@ExtendWith(SpringExtension.class)
// ApplicationContext will be loaded from "/app-config.xml" and
// "/test-config.xml" in the root of the classpath
@ContextConfiguration(locations = {"/app-config.xml", "/test-config.xml"}) (1)
class MyTest {
// class body...
1 | Setting the locations attribute to a list of XML files. |
@ExtendWith(SpringExtension::class)
@ContextConfiguration(locations = ["/app-config.xml", "/test-config.xml"]) (1)
class MyTest {
// class body...
supports an alias for the locations
attribute through the
standard Java value
attribute. Thus, if you do not need to declare additional
attributes in @ContextConfiguration
, you can omit the declaration of the locations
attribute name and declare the resource locations by using the shorthand format
demonstrated in the following example:
Java
Kotlin
@ContextConfiguration({"/app-config.xml", "/test-config.xml"}) (1)
class MyTest {
// class body...
1 | Specifying XML files without using the locations attribute. |
@ContextConfiguration("/app-config.xml", "/test-config.xml") (1)
class MyTest {
// class body...
If you omit both the locations
and the value
attributes from the
annotation, the TestContext framework tries to detect a default
XML resource location. Specifically, GenericXmlContextLoader
and
GenericXmlWebContextLoader
detect a default location based on the name of the test
class. If your class is named com.example.MyTest
loads your
application context from "classpath:com/example/MyTest-context.xml"
. The following
example shows how to do so:
Java
Kotlin
// "classpath:com/example/MyTest-context.xml"
@ContextConfiguration (1)
class MyTest {
// class body...
1 | Loading configuration from the default location. |
class MyTest {
// class body...
