This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Filter Registrations
When setting up a MockMvc instance, you can register one or more Servlet Filter instances, as the following example shows:spring-doc.cn
mockMvc = standaloneSetup(new PersonController()).addFilters(new CharacterEncodingFilter()).build();
// Not possible in Kotlin until {kotlin-issues}/KT-22208 is fixed
Registered filters are invoked through the MockFilterChain from spring-test, and the last filter delegates to the DispatcherServlet.spring-doc.cn
