This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Defining New Advice Types
Spring AOP is designed to be extensible. While the interception implementation strategy is presently used internally, it is possible to support arbitrary advice types in addition to the interception around advice, before, throws advice, and after returning advice.
The org.springframework.aop.framework.adapter
package is an SPI package that lets
support for new custom advice types be added without changing the core framework.
The only constraint on a custom Advice
type is that it must implement the
org.aopalliance.aop.Advice
marker interface.
See the org.springframework.aop.framework.adapter
javadoc for further information.
