This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Ahead of Time Support for Tests
This chapter covers Spring’s Ahead of Time (AOT) support for integration tests using the Spring TestContext Framework.
The testing support extends Spring’s core AOT support with the following features.
Build-time detection of all integration tests in the current project that use the TestContext framework to load an
ApplicationContext
Provides explicit support for test classes based on JUnit Jupiter and JUnit 4 as well as implicit support for TestNG and other testing frameworks that use Spring’s core testing annotations — as long as the tests are run using a JUnit Platform
TestEngine
that is registered for the current project.
Build-time AOT processing: each unique test
ApplicationContext
in the current project will be refreshed for AOT processing. -
Runtime AOT support: when executing in AOT runtime mode, a Spring integration test will use an AOT-optimized
ApplicationContext
that participates transparently with the context cache.
All tests are enabled in AOT mode by default. However, you can selectively disable an
entire test class or individual test method in AOT mode by annotating it with
@DisabledInAotMode
When using JUnit Jupiter, you may selectively enable or disable tests in a GraalVM native
image via Jupiter’s @EnabledInNativeImage
and @DisabledInNativeImage
annotations.
Note that @DisabledInAotMode
also disables the annotated test class or test method when
running within a GraalVM native image, analogous to JUnit Jupiter’s
annotation.
By default, if an error is encountered during build-time AOT processing, an exception will be thrown, and the overall process will fail immediately. If you would prefer that build-time AOT processing continue after errors are encountered,
you can disable the The |
The |
To provide test-specific runtime hints for use within a GraalVM native image, you have the following options.
Implement a custom
TestRuntimeHintsRegistrar
and register it globally viaMETA-INF/spring/aot.factories
Implement a custom
or locally on a test class via@ImportRuntimeHints
Annotate a test class with
@Reflective
or@RegisterReflectionForBinding
See Runtime Hints for details on Spring’s core runtime hints and annotation support.
The |
If you implement a custom ContextLoader
, it must implement
AotContextLoader
in
order to provide AOT build-time processing and AOT runtime execution support. Note,
however, that all context loader implementations provided by the Spring Framework and
Spring Boot already implement AotContextLoader
If you implement a custom TestExecutionListener
, it must implement
AotTestExecutionListener
in order to participate in AOT processing. See the SqlScriptsTestExecutionListener
in
the spring-test
module for an example.
