This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Advising Transactional Operations
Suppose you want to run both transactional operations and some basic profiling advice.
How do you effect this in the context of <tx:annotation-driven/>
When you invoke the updateFoo(Foo)
method, you want to see the following actions:
The configured profiling aspect starts.
The transactional advice runs.
The method on the advised object runs.
The transaction commits.
The profiling aspect reports the exact duration of the whole transactional method invocation.
This chapter is not concerned with explaining AOP in any great detail (except as it applies to transactions). See AOP for detailed coverage of the AOP configuration and AOP in general. |
The following code shows the simple profiling aspect discussed earlier:
Java
Kotlin
package x.y;
import org.aspectj.lang.ProceedingJoinPoint;
import org.springframework.util.StopWatch;
import org.springframework.core.Ordered;
public class SimpleProfiler implements Ordered {
private int order;
// allows us to control the ordering of advice
public int getOrder() {
return this.order;
public void setOrder(int order) {
this.order = order;
// this method is the around advice
public Object profile(ProceedingJoinPoint call) throws Throwable {
Object returnValue;
StopWatch clock = new StopWatch(getClass().getName());
try {
clock.start(call.toShortString());
returnValue = call.proceed();
} finally {
clock.stop();
System.out.println(clock.prettyPrint());
return returnValue;
package x.y
class SimpleProfiler : Ordered {
private var order: Int = 0
override fun getOrder(): Int {
return this.order
fun setOrder(order: Int) {
this.order = order
fun profile(call: ProceedingJoinPoint): Any {
var returnValue: Any
val clock = StopWatch(javaClass.name)
try {
} finally {
clock.stop()
return returnValue
The ordering of advice
is controlled through the Ordered
interface. For full details on advice ordering, see
Advice ordering.
The following configuration creates a fooService
bean that has profiling and
transactional aspects applied to it in the desired order:
xmlns:aop="http://www.springframework.org/schema/aop"
xmlns:tx="http://www.springframework.org/schema/tx"
xsi:schemaLocation="
https://www.springframework.org/schema/tx/spring-tx.xsd
https://www.springframework.org/schema/aop/spring-aop.xsd">
<bean id="fooService" class="x.y.service.DefaultFooService"/>
<!-- this is the aspect -->
<bean id="profiler" class="x.y.SimpleProfiler">
<!-- run before the transactional advice (hence the lower order number) -->
<property name="order" value="1"/>
</bean>
<tx:annotation-driven transaction-manager="txManager" order="200"/>
<aop:config>
<!-- this advice runs around the transactional advice -->
<aop:aspect id="profilingAspect" ref="profiler">
<aop:pointcut id="serviceMethodWithReturnValue"
expression="execution(!void x.y..*Service.*(..))"/>
<aop:around method="profile" pointcut-ref="serviceMethodWithReturnValue"/>
</aop:aspect>
</aop:config>
<bean id="dataSource" class="org.apache.commons.dbcp.BasicDataSource" destroy-method="close">
<property name="driverClassName" value="oracle.jdbc.driver.OracleDriver"/>
<property name="url" value="jdbc:oracle:thin:@rj-t42:1521:elvis"/>
<property name="username" value="scott"/>
<property name="password" value="tiger"/>
</bean>
<bean id="txManager" class="org.springframework.jdbc.datasource.DataSourceTransactionManager">
<property name="dataSource" ref="dataSource"/>
</bean>
</beans>
You can configure any number of additional aspects in similar fashion.
The following example creates the same setup as the previous two examples but uses the purely XML declarative approach:
<!-- the profiling advice -->
</bean>
<aop:config>
<aop:pointcut id="entryPointMethod" expression="execution(* x.y..*Service.*(..))"/>
<!-- runs after the profiling advice (cf. the order attribute) -->
<aop:advisor advice-ref="txAdvice" pointcut-ref="entryPointMethod" order="2"/>
<!-- order value is higher than the profiling aspect -->
</aop:aspect>
</aop:config>
<tx:advice id="txAdvice" transaction-manager="txManager">
<tx:attributes>
<tx:method name="get*" read-only="true"/>
<tx:method name="*"/>
</tx:attributes>
</tx:advice>
<!-- other <bean/> definitions such as a DataSource and a TransactionManager here -->
</beans>
The result of the preceding configuration is a fooService
transactional aspects applied to it in that order. If you want the profiling advice
to run after the transactional advice on the way in and before the
transactional advice on the way out, you can swap the value of the profiling
aspect bean’s order
property so that it is higher than the transactional advice’s
order value.
You can configure additional aspects in similar fashion.
