This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Using JSR-160 Connectors
For remote access, Spring JMX module offers two FactoryBean
implementations inside the
org.springframework.jmx.support
package for creating both server- and client-side
connectors.
Server-side Connectors
To have Spring JMX create, start, and expose a JSR-160 JMXConnectorServer
, you can use the
following configuration:
<bean id="serverConnector" class="org.springframework.jmx.support.ConnectorServerFactoryBean"/>
By default, ConnectorServerFactoryBean
creates a JMXConnectorServer
bound to
service:jmx:jmxmp://localhost:9875
. The serverConnector
bean thus exposes the
local MBeanServer
to clients through the JMXMP protocol on localhost, port 9875. Note
that the JMXMP protocol is marked as optional by the JSR 160 specification. Currently,
the main open-source JMX implementation, MX4J, and the one provided with the JDK
do not support JMXMP.
To specify another URL and register the JMXConnectorServer
itself with the
MBeanServer
, you can use the serviceUrl
and ObjectName
properties, respectively,
as the following example shows:
class="org.springframework.jmx.support.ConnectorServerFactoryBean">
<property name="objectName" value="connector:name=rmi"/>
<property name="serviceUrl"
value="service:jmx:rmi://localhost/jndi/rmi://localhost:1099/myconnector"/>
</bean>
If the ObjectName
property is set, Spring automatically registers your connector
with the MBeanServer
under that ObjectName
. The following example shows the full set of
parameters that you can pass to the ConnectorServerFactoryBean
when creating a
JMXConnector
<property name="objectName" value="connector:name=iiop"/>
value="service:jmx:iiop://localhost/jndi/iiop://localhost:900/myconnector"/>
<property name="threaded" value="true"/>
<property name="daemon" value="true"/>
<property name="environment">
<map>
<entry key="someKey" value="someValue"/>
</map>
</property>
</bean>
Note that, when you use a RMI-based connector, you need the lookup service (tnameserv
or
rmiregistry
) to be started in order for the name registration to complete.
Client-side Connectors
To create an MBeanServerConnection
to a remote JSR-160-enabled MBeanServer
, you can use the
MBeanServerConnectionFactoryBean
, as the following example shows:
<bean id="clientConnector" class="org.springframework.jmx.support.MBeanServerConnectionFactoryBean">
<property name="serviceUrl" value="service:jmx:rmi://localhost/jndi/rmi://localhost:1099/jmxrmi"/>
</bean>
JMX over Hessian or SOAP
JSR-160 permits extensions to the way in which communication is done between the client and the server. The examples shown in the preceding sections use the mandatory RMI-based implementation required by the JSR-160 specification (IIOP and JRMP) and the (optional) JMXMP. By using other providers or JMX implementations (such as MX4J) you can take advantage of protocols such as SOAP or Hessian over simple HTTP or SSL and others, as the following example shows:
<bean id="serverConnector" class="org.springframework.jmx.support.ConnectorServerFactoryBean">
<property name="objectName" value="connector:name=burlap"/>
<property name="serviceUrl" value="service:jmx:burlap://localhost:9874"/>
</bean>
In the preceding example, we used MX4J 3.0.0. See the official MX4J documentation for more information.
