This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
External Broker
The simple broker is great for getting started but supports only a subset of STOMP commands (it does not support acks, receipts, and some other features), relies on a simple message-sending loop, and is not suitable for clustering. As an alternative, you can upgrade your applications to use a full-featured message broker.spring-doc.cn
See the STOMP documentation for your message broker of choice (such as RabbitMQ, ActiveMQ, and others), install the broker, and run it with STOMP support enabled. Then you can enable the STOMP broker relay (instead of the simple broker) in the Spring configuration.spring-doc.cn
The following example configuration enables a full-featured broker:spring-doc.cn
@EnableWebSocketMessageBroker
public class WebSocketConfig implements WebSocketMessageBrokerConfigurer {
	public void registerStompEndpoints(StompEndpointRegistry registry) {
		registry.addEndpoint("/portfolio").withSockJS();
	public void configureMessageBroker(MessageBrokerRegistry registry) {
		registry.enableStompBrokerRelay("/topic", "/queue");
		registry.setApplicationDestinationPrefixes("/app");
The following example shows the XML configuration equivalent of the preceding example:spring-doc.cn
	xmlns:websocket="http://www.springframework.org/schema/websocket"
	xsi:schemaLocation="
		https://www.springframework.org/schema/websocket/spring-websocket.xsd">
	<websocket:message-broker application-destination-prefix="/app">
		<websocket:stomp-endpoint path="/portfolio" />
			<websocket:sockjs/>
		</websocket:stomp-endpoint>
		<websocket:stomp-broker-relay prefix="/topic,/queue" />
	</websocket:message-broker>
</beans>
The STOMP broker relay in the preceding configuration is a Spring MessageHandler that handles messages by forwarding them to an external message broker. To do so, it establishes TCP connections to the broker, forwards all messages to it, and then forwards all messages received from the broker to clients through their WebSocket sessions. Essentially, it acts as a “relay” that forwards messages in both directions.spring-doc.cn
Add io.projectreactor.netty:reactor-netty and io.netty:netty-all dependencies to your project for TCP connection management.
Furthermore, application components (such as HTTP request handling methods, business services, and others) can also send messages to the broker relay, as described in Sending Messages, to broadcast messages to subscribed WebSocket clients.spring-doc.cn
In effect, the broker relay enables robust and scalable message broadcasting.spring-doc.cn
