This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
<tx:advice/> Settings
This section summarizes the various transactional settings that you can specify by using
the <tx:advice/>
tag. The default <tx:advice/>
settings are:
The propagation setting is
REQUIRED.
The isolation level is
DEFAULT.
The transaction is read-write.
The transaction timeout defaults to the default timeout of the underlying transaction system or none if timeouts are not supported.
Any
RuntimeException
triggers rollback, and any checkedException
does not.
You can change these default settings. The following table summarizes the various attributes of the <tx:method/>
tags
that are nested within <tx:advice/>
and <tx:attributes/>
tags:
Attribute | Required? | Default | Description |
Yes |
Method names with which the transaction attributes are to be associated. The
wildcard (*) character can be used to associate the same transaction attribute
settings with a number of methods (for example, |
No |
Transaction propagation behavior. |
No |
Transaction isolation level. Only applicable to propagation settings of |
No |
-1 |
Transaction timeout (seconds). Only applicable to propagation |
No |
false |
Read-write versus read-only transaction. Applies only to |
No |
Comma-delimited list of |
No |
