This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Configuring a Global Date and Time Format
By default, date and time fields not annotated with @DateTimeFormat
are converted from
strings by using the DateFormat.SHORT
style. If you prefer, you can change this by
defining your own global format.
To do that, ensure that Spring does not register default formatters. Instead, register formatters manually with the help of:
org.springframework.format.datetime.standard.DateTimeFormatterRegistrar
org.springframework.format.datetime.DateFormatterRegistrar
For example, the following Java configuration registers a global yyyyMMdd
format:
Java
Kotlin
public class AppConfig {
public FormattingConversionService conversionService() {
// Use the DefaultFormattingConversionService but do not register defaults
DefaultFormattingConversionService conversionService =
new DefaultFormattingConversionService(false);
// Ensure @NumberFormat is still supported
conversionService.addFormatterForFieldAnnotation(
new NumberFormatAnnotationFormatterFactory());
// Register JSR-310 date conversion with a specific global format
DateTimeFormatterRegistrar dateTimeRegistrar = new DateTimeFormatterRegistrar();
dateTimeRegistrar.setDateFormatter(DateTimeFormatter.ofPattern("yyyyMMdd"));
dateTimeRegistrar.registerFormatters(conversionService);
// Register date conversion with a specific global format
DateFormatterRegistrar dateRegistrar = new DateFormatterRegistrar();
dateRegistrar.setFormatter(new DateFormatter("yyyyMMdd"));
dateRegistrar.registerFormatters(conversionService);
return conversionService;
class AppConfig {
fun conversionService(): FormattingConversionService {
return DefaultFormattingConversionService(false).apply {
addFormatterForFieldAnnotation(NumberFormatAnnotationFormatterFactory())
val dateTimeRegistrar = DateTimeFormatterRegistrar()
dateTimeRegistrar.registerFormatters(this)
val dateRegistrar = DateFormatterRegistrar()
dateRegistrar.setFormatter(DateFormatter("yyyyMMdd"))
dateRegistrar.registerFormatters(this)
If you prefer XML-based configuration, you can use a
FormattingConversionServiceFactoryBean
. The following example shows how to do so:
xsi:schemaLocation="
https://www.springframework.org/schema/beans/spring-beans.xsd">
<bean id="conversionService" class="org.springframework.format.support.FormattingConversionServiceFactoryBean">
<property name="registerDefaultFormatters" value="false" />
<property name="formatters">
<set>
<bean class="org.springframework.format.number.NumberFormatAnnotationFormatterFactory" />
</set>
</property>
<property name="formatterRegistrars">
<set>
<bean class="org.springframework.format.datetime.standard.DateTimeFormatterRegistrar">
<property name="dateFormatter">
<bean class="org.springframework.format.datetime.standard.DateTimeFormatterFactoryBean">
<property name="pattern" value="yyyyMMdd"/>
</bean>
</property>
</bean>
</set>
</property>
</bean>
</beans>
Note there are extra considerations when configuring date and time formats in web applications. Please see WebMVC Conversion and Formatting or WebFlux Conversion and Formatting.
