This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Context
Attributes provide a convenient way to pass information to the filter chain but they only influence the current request. If you want to pass information that propagates to additional requests that are nested, e.g. via flatMap, or executed after, e.g. via concatMap, then you’ll need to use the Reactor Context.spring-doc.cn
The Reactor Context needs to be populated at the end of a reactive chain in order to apply to all operations. For example:spring-doc.cn
WebClient client = WebClient.builder()
		.filter((request, next) ->
				Mono.deferContextual(contextView -> {
					String value = contextView.get("foo");
client.get().uri("https://example.org/")
		.retrieve()
		.bodyToMono(String.class)
		.flatMap(body -> {
				// perform nested request (context propagates automatically)...
		.contextWrite(context -> context.put("foo", ...));
