This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Annotated Controllers
Spring MVC provides an annotation-based programming model where @Controller
and
@RestController
components use annotations to express request mappings, request input,
exception handling, and more. Annotated controllers have flexible method signatures and
do not have to extend base classes nor implement specific interfaces.
The following example shows a controller defined by annotations:
Java
Kotlin
@Controller
public class HelloController {
@GetMapping("/hello")
public String handle(Model model) {
model.addAttribute("message", "Hello World!");
return "index";
import org.springframework.ui.set
@Controller
fun handle(model: Model): String {
model["message"] = "Hello World!"
return "index"
In the preceding example, the method accepts a Model
and returns a view name as a String
but many other options exist and are explained later in this chapter.
Guides and tutorials on spring.io use the annotation-based programming model described in this section. |
