This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Getting Started
The easiest way to learn how to build a Spring application with Kotlin is to follow the dedicated tutorial.spring-doc.cn
start.spring.io
The easiest way to start a new Spring Framework project in Kotlin is to create a new Spring Boot project on start.spring.io.spring-doc.cn
Choosing the Web Flavor
Spring Framework comes with two different web stacks: Spring MVC and Spring WebFlux.spring-doc.cn
Spring WebFlux is recommended if you want to create applications that will deal with latency, long-lived connections or streaming scenarios.spring-doc.cn
For other use cases, especially if you are using blocking technologies such as JPA, Spring MVC is the recommended choice.spring-doc.cn
