This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
HTTP Caching
HTTP caching can significantly improve the performance of a web application. HTTP caching
revolves around the Cache-Control
response header and subsequent conditional request
headers, such as Last-Modified
and ETag
. Cache-Control
advises private (for example, browser)
and public (for example, proxy) caches how to cache and re-use responses. An ETag
header is used
to make a conditional request that may result in a 304 (NOT_MODIFIED) without a body,
if the content has not changed. ETag
can be seen as a more sophisticated successor to
the Last-Modified
header.
This section describes the HTTP caching related options available in Spring WebFlux.
CacheControl
CacheControl
provides support for
configuring settings related to the Cache-Control
header and is accepted as an argument
in a number of places:
While RFC 7234 describes all possible
directives for the Cache-Control
response header, the CacheControl
type takes a
use case-oriented approach that focuses on the common scenarios, as the following example shows:
Java
Kotlin
// Cache for an hour - "Cache-Control: max-age=3600"
CacheControl ccCacheOneHour = CacheControl.maxAge(1, TimeUnit.HOURS);
// Prevent caching - "Cache-Control: no-store"
CacheControl ccNoStore = CacheControl.noStore();
// Cache for ten days in public and private caches,
// public caches should not transform the response
// "Cache-Control: max-age=864000, public, no-transform"
CacheControl ccCustom = CacheControl.maxAge(10, TimeUnit.DAYS).noTransform().cachePublic();
val ccCacheOneHour = CacheControl.maxAge(1, TimeUnit.HOURS)
val ccNoStore = CacheControl.noStore()
val ccCustom = CacheControl.maxAge(10, TimeUnit.DAYS).noTransform().cachePublic()
Controllers
Controllers can add explicit support for HTTP caching. We recommend doing so, since the
lastModified
or ETag
value for a resource needs to be calculated before it can be compared
against conditional request headers. A controller can add an ETag
and Cache-Control
settings to a ResponseEntity
Java
Kotlin
@GetMapping("/book/{id}")
public ResponseEntity<Book> showBook(@PathVariable Long id) {
Book book = findBook(id);
String version = book.getVersion();
return ResponseEntity
.ok()
.cacheControl(CacheControl.maxAge(30, TimeUnit.DAYS))
.eTag(version) // lastModified is also available
.body(book);
fun showBook(@PathVariable id: Long): ResponseEntity<Book> {
val book = findBook(id)
val version = book.getVersion()
.ok()
.body(book)
The preceding example sends a 304 (NOT_MODIFIED) response with an empty body if the comparison
to the conditional request headers indicates the content has not changed. Otherwise, the
ETag
and Cache-Control
headers are added to the response.
You can also make the check against conditional request headers in the controller, as the following example shows:
Java
Kotlin
@RequestMapping
public String myHandleMethod(ServerWebExchange exchange, Model model) {
long eTag = ... (1)
if (exchange.checkNotModified(eTag)) {
return null; (2)
model.addAttribute(...); (3)
return "myViewName";
1 | Application-specific calculation. |
2 | Response has been set to 304 (NOT_MODIFIED). No further processing. |
3 | Continue with request processing. |
@RequestMapping
fun myHandleMethod(exchange: ServerWebExchange, model: Model): String? {
val eTag: Long = ... (1)
return null(2)
model.addAttribute(...) (3)
return "myViewName"
There are three variants for checking conditional requests against eTag
values, lastModified
values, or both. For conditional GET
and HEAD
requests, you can set the response to
304 (NOT_MODIFIED). For conditional POST
, PUT
, and DELETE
, you can instead set the response
to 412 (PRECONDITION_FAILED) to prevent concurrent modification.
Static Resources
You should serve static resources with a Cache-Control
and conditional response headers
for optimal performance. See the section on configuring Static Resources.
