This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Spring Field Formatting
As discussed in the previous section, core.convert
is a
general-purpose type conversion system. It provides a unified ConversionService
API as
well as a strongly typed Converter
SPI for implementing conversion logic from one type
to another. A Spring container uses this system to bind bean property values. In
addition, both the Spring Expression Language (SpEL) and DataBinder
use this system to
bind field values. For example, when SpEL needs to coerce a Short
to a Long
to
complete an expression.setValue(Object bean, Object value)
attempt, the core.convert
system performs the coercion.
Now consider the type conversion requirements of a typical client environment, such as a
web or desktop application. In such environments, you typically convert from String
to support the client postback process, as well as back to String
to support the
view rendering process. In addition, you often need to localize String
values. The more
general core.convert
Converter
SPI does not address such formatting requirements
directly. To directly address them, Spring provides a convenient Formatter
SPI that
provides a simple and robust alternative to PropertyEditor
implementations for client
environments.
In general, you can use the Converter
SPI when you need to implement general-purpose type
conversion logic — for example, for converting between a java.util.Date
and a Long
You can use the Formatter
SPI when you work in a client environment (such as a web
application) and need to parse and print localized field values. The ConversionService
provides a unified type conversion API for both SPIs.
The Formatter
SPI
The Formatter
SPI to implement field formatting logic is simple and strongly typed. The
following listing shows the Formatter
interface definition:
package org.springframework.format;
public interface Formatter<T> extends Printer<T>, Parser<T> {
Formatter
extends from the Printer
and Parser
building-block interfaces. The
following listing shows the definitions of those two interfaces:
public interface Printer<T> {
String print(T fieldValue, Locale locale);
import java.text.ParseException;
public interface Parser<T> {
T parse(String clientValue, Locale locale) throws ParseException;
To create your own Formatter
, implement the Formatter
interface shown earlier.
Parameterize T
to be the type of object you wish to format — for example,
java.util.Date
. Implement the print()
operation to print an instance of T
for
display in the client locale. Implement the parse()
operation to parse an instance of
T
from the formatted representation returned from the client locale. Your Formatter
should throw a ParseException
or an IllegalArgumentException
if a parse attempt fails. Take
care to ensure that your Formatter
implementation is thread-safe.
The format
subpackages provide several Formatter
implementations as a convenience.
The number
package provides NumberStyleFormatter
, CurrencyStyleFormatter
, and
PercentStyleFormatter
to format Number
objects that use a java.text.NumberFormat
The datetime
package provides a DateFormatter
to format java.util.Date
objects with
a java.text.DateFormat
The following DateFormatter
is an example Formatter
implementation:
Java
Kotlin
package org.springframework.format.datetime;
public final class DateFormatter implements Formatter<Date> {
private String pattern;
public DateFormatter(String pattern) {
this.pattern = pattern;
public String print(Date date, Locale locale) {
if (date == null) {
return "";
return getDateFormat(locale).format(date);
public Date parse(String formatted, Locale locale) throws ParseException {
if (formatted.length() == 0) {
return null;
return getDateFormat(locale).parse(formatted);
protected DateFormat getDateFormat(Locale locale) {
DateFormat dateFormat = new SimpleDateFormat(this.pattern, locale);
dateFormat.setLenient(false);
return dateFormat;
class DateFormatter(private val pattern: String) : Formatter<Date> {
override fun print(date: Date, locale: Locale)
= getDateFormat(locale).format(date)
@Throws(ParseException::class)
override fun parse(formatted: String, locale: Locale)
= getDateFormat(locale).parse(formatted)
protected fun getDateFormat(locale: Locale): DateFormat {
val dateFormat = SimpleDateFormat(this.pattern, locale)
dateFormat.isLenient = false
return dateFormat
The Spring team welcomes community-driven Formatter
contributions. See
GitHub Issues to contribute.
Annotation-driven Formatting
Field formatting can be configured by field type or annotation. To bind
an annotation to a Formatter
, implement AnnotationFormatterFactory
. The following
listing shows the definition of the AnnotationFormatterFactory
interface:
public interface AnnotationFormatterFactory<A extends Annotation> {
Set<Class<?>> getFieldTypes();
Printer<?> getPrinter(A annotation, Class<?> fieldType);
Parser<?> getParser(A annotation, Class<?> fieldType);
To create an implementation:
Parameterize
A
to be the fieldannotationType
with which you wish to associate formatting logic — for exampleorg.springframework.format.annotation.DateTimeFormat
Have
getFieldTypes()
return the types of fields on which the annotation can be used. -
Have
getPrinter()
return aPrinter
to print the value of an annotated field. -
Have
getParser()
return aParser
to parse aclientValue
for an annotated field.
The following example AnnotationFormatterFactory
implementation binds the @NumberFormat
annotation to a formatter to let a number style or pattern be specified:
Java
Kotlin
public final class NumberFormatAnnotationFormatterFactory
implements AnnotationFormatterFactory<NumberFormat> {
private static final Set<Class<?>> FIELD_TYPES = Set.of(Short.class,
Integer.class, Long.class, Float.class, Double.class,
BigDecimal.class, BigInteger.class);
public Set<Class<?>> getFieldTypes() {
return FIELD_TYPES;
public Printer<Number> getPrinter(NumberFormat annotation, Class<?> fieldType) {
return configureFormatterFrom(annotation, fieldType);
public Parser<Number> getParser(NumberFormat annotation, Class<?> fieldType) {
private Formatter<Number> configureFormatterFrom(NumberFormat annotation, Class<?> fieldType) {
if (!annotation.pattern().isEmpty()) {
return new NumberStyleFormatter(annotation.pattern());
// else
return switch(annotation.style()) {
case Style.PERCENT -> new PercentStyleFormatter();
case Style.CURRENCY -> new CurrencyStyleFormatter();
default -> new NumberStyleFormatter();
class NumberFormatAnnotationFormatterFactory : AnnotationFormatterFactory<NumberFormat> {
override fun getFieldTypes(): Set<Class<*>> {
return setOf(Short::class.java, Int::class.java, Long::class.java, Float::class.java, Double::class.java, BigDecimal::class.java, BigInteger::class.java)
override fun getPrinter(annotation: NumberFormat, fieldType: Class<*>): Printer<Number> {
override fun getParser(annotation: NumberFormat, fieldType: Class<*>): Parser<Number> {
private fun configureFormatterFrom(annotation: NumberFormat, fieldType: Class<*>): Formatter<Number> {
return if (annotation.pattern.isNotEmpty()) {
NumberStyleFormatter(annotation.pattern)
} else {
val style = annotation.style
when {
style === NumberFormat.Style.PERCENT -> PercentStyleFormatter()
style === NumberFormat.Style.CURRENCY -> CurrencyStyleFormatter()
else -> NumberStyleFormatter()
To trigger formatting, you can annotate fields with @NumberFormat
, as the following
example shows:
Java
Kotlin
public class MyModel {
@NumberFormat(style=Style.CURRENCY)
private BigDecimal decimal;
class MyModel(
@field:NumberFormat(style = Style.CURRENCY) private val decimal: BigDecimal
Format Annotation API
A portable format annotation API exists in the org.springframework.format.annotation
package. You can use @NumberFormat
to format Number
fields such as Double
and
Long
, and @DateTimeFormat
to format fields such as java.util.Date
java.util.Calendar
, and Long
(for millisecond timestamps) as well as JSR-310
java.time
types.
The following example uses @DateTimeFormat
to format a java.util.Date
as an ISO date
(yyyy-MM-dd):
Java
Kotlin
@DateTimeFormat(iso=ISO.DATE)
private Date date;
class MyModel(
@DateTimeFormat(iso=ISO.DATE) private val date: Date
For further details, see the javadoc for
@DateTimeFormat
and
@NumberFormat
Style-based formatting and parsing rely on locale-sensitive patterns which may change depending on the Java runtime. Specifically, applications that rely on date, time, or number parsing and formatting may encounter incompatible changes in behavior when running on JDK 20 or higher. Using an ISO standardized format or a concrete pattern that you control allows for reliable system-independent and locale-independent parsing and formatting of date, time, and number values. For For further details, see the Date and Time Formatting with JDK 20 and higher page in the Spring Framework wiki. |
The FormatterRegistry
SPI
is an SPI for registering formatters and converters.
FormattingConversionService
is an implementation of FormatterRegistry
suitable for
most environments. You can programmatically or declaratively configure this variant
as a Spring bean, e.g. by using FormattingConversionServiceFactoryBean
. Because this
implementation also implements ConversionService
, you can directly configure it
for use with Spring’s DataBinder
and the Spring Expression Language (SpEL).
The following listing shows the FormatterRegistry
SPI:
public interface FormatterRegistry extends ConverterRegistry {
void addPrinter(Printer<?> printer);
void addParser(Parser<?> parser);
void addFormatter(Formatter<?> formatter);
void addFormatterForFieldType(Class<?> fieldType, Formatter<?> formatter);
void addFormatterForFieldType(Class<?> fieldType, Printer<?> printer, Parser<?> parser);
void addFormatterForFieldAnnotation(AnnotationFormatterFactory<? extends Annotation> annotationFormatterFactory);
As shown in the preceding listing, you can register formatters by field type or by annotation.
SPI lets you configure formatting rules centrally, instead of
duplicating such configuration across your controllers. For example, you might want to
enforce that all date fields are formatted a certain way or that fields with a specific
annotation are formatted in a certain way. With a shared FormatterRegistry
, you define
these rules once, and they are applied whenever formatting is needed.
The FormatterRegistrar
SPI
FormatterRegistrar
is an SPI for registering formatters and converters through the
FormatterRegistry. The following listing shows its interface definition:
public interface FormatterRegistrar {
void registerFormatters(FormatterRegistry registry);
A FormatterRegistrar
is useful when registering multiple related converters and
formatters for a given formatting category, such as date formatting. It can also be
useful where declarative registration is insufficient — for example, when a formatter
needs to be indexed under a specific field type different from its own <T>
or when
registering a Printer
/Parser
pair. The next section provides more information on
converter and formatter registration.
Configuring Formatting in Spring MVC
See Conversion and Formatting in the Spring MVC chapter.
