This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Reactive Libraries
spring-webflux depends on reactor-core and uses it internally to compose asynchronous logic and to provide Reactive Streams support. Generally, WebFlux APIs return Flux or Mono (since those are used internally) and leniently accept any Reactive Streams Publisher implementation as input. When a Publisher is provided, it can be treated only as a stream with unknown semantics (0..N). If, however, the semantics are known, you should wrap it with Flux or Mono.from(Publisher) instead of passing the raw Publisher. The use of Flux versus Mono is important, because it helps to express cardinality — for example, whether a single or multiple asynchronous values are expected, and that can be essential for making decisions (for example, when encoding or decoding HTTP messages).spring-doc.cn
For annotated controllers, WebFlux transparently adapts to the reactive library chosen by the application. This is done with the help of the ReactiveAdapterRegistry, which provides pluggable support for reactive library and other asynchronous types. The registry has built-in support for RxJava 3, Kotlin coroutines and SmallRye Mutiny, but you can register others, too.spring-doc.cn
