This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Dependencies
A typical enterprise application does not consist of a single object (or bean in the Spring parlance). Even the simplest application has a few objects that work together to present what the end-user sees as a coherent application. This next section explains how you go from defining a number of bean definitions that stand alone to a fully realized application where objects collaborate to achieve a goal.
