This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Enable MVC Configuration
In Java configuration, you can use the @EnableWebMvc annotation to enable MVC configuration, as the following example shows:spring-doc.cn
@EnableWebMvc
public class WebConfig {
@EnableWebMvc
class WebConfig
In XML configuration, you can use the <mvc:annotation-driven> element to enable MVC configuration, as the following example shows:spring-doc.cn
	xmlns:mvc="http://www.springframework.org/schema/mvc"
	xsi:schemaLocation="
		https://www.springframework.org/schema/mvc/spring-mvc.xsd">
	<mvc:annotation-driven/>
</beans>
The preceding example registers a number of Spring MVC infrastructure beans and adapts to dependencies available on the classpath (for example, payload converters for JSON, XML, and others).spring-doc.cn
