This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Enable STOMP
STOMP over WebSocket support is available in the spring-messaging
and
spring-websocket
modules. Once you have those dependencies, you can expose a STOMP
endpoint over WebSocket, as the following example shows:
import org.springframework.web.socket.config.annotation.EnableWebSocketMessageBroker;
import org.springframework.web.socket.config.annotation.StompEndpointRegistry;
@EnableWebSocketMessageBroker
public class WebSocketConfig implements WebSocketMessageBrokerConfigurer {
public void registerStompEndpoints(StompEndpointRegistry registry) {
registry.addEndpoint("/portfolio"); (1)
public void configureMessageBroker(MessageBrokerRegistry config) {
config.setApplicationDestinationPrefixes("/app"); (2)
config.enableSimpleBroker("/topic", "/queue"); (3)
1 | /portfolio is the HTTP URL for the endpoint to which a WebSocket (or SockJS)
client needs to connect for the WebSocket handshake. |
2 | STOMP messages whose destination header begins with /app are routed to
@MessageMapping methods in @Controller classes. |
3 | Use the built-in message broker for subscriptions and broadcasting and
route messages whose destination header begins with /topic or /queue to the broker. |
The following example shows the XML configuration equivalent of the preceding example:
xmlns:websocket="http://www.springframework.org/schema/websocket"
xsi:schemaLocation="
https://www.springframework.org/schema/websocket/spring-websocket.xsd">
<websocket:message-broker application-destination-prefix="/app">
<websocket:stomp-endpoint path="/portfolio" />
<websocket:simple-broker prefix="/topic, /queue"/>
</websocket:message-broker>
</beans>
For the built-in simple broker, the /topic and /queue prefixes do not have any special
meaning. They are merely a convention to differentiate between pub-sub versus point-to-point
messaging (that is, many subscribers versus one consumer). When you use an external broker,
check the STOMP page of the broker to understand what kind of STOMP destinations and
prefixes it supports.
To connect from a browser, for STOMP, you can use
stomp-js/stompjs
which is the most
actively maintained JavaScript library.
The following example code is based on it:
const stompClient = new StompJs.Client({
brokerURL: 'ws://domain.com/portfolio',
onConnect: () => {
Alternatively, if you connect through SockJS, you can enable the
SockJS Fallback on server-side with
registry.addEndpoint("/portfolio").withSockJS()
and on JavaScript side,
by following
those instructions.
Note that stompClient
in the preceding example does not need to specify login
and passcode
headers. Even if it did, they would be ignored (or, rather,
overridden) on the server side. See Connecting to a Broker
and Authentication for more information on authentication.
For more example code see:
Using WebSocket to build an interactive web application — a getting started guide.
Stock Portfolio — a sample application.
