This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
WebTestClient
WebTestClient is an HTTP client designed for testing server applications. It wraps Spring’s WebClient and uses it to perform requests but exposes a testing facade for verifying responses. WebTestClient can be used to perform end-to-end HTTP tests. It can also be used to test Spring MVC and Spring WebFlux applications without a running server via mock server request and response objects.spring-doc.cn
Setup
To set up a WebTestClient you need to choose a server setup to bind to. This can be one of several mock server setup choices or a connection to a live server.spring-doc.cn
Bind to Controller
This setup allows you to test specific controller(s) via mock request and response objects, without a running server.spring-doc.cn
For WebFlux applications, use the following which loads infrastructure equivalent to the WebFlux Java config, registers the given controller(s), and creates a WebHandler chain to handle requests:spring-doc.cn
WebTestClient client =
		WebTestClient.bindToController(new TestController()).build();
val client = WebTestClient.bindToController(TestController()).build()
For Spring MVC, use the following which delegates to the StandaloneMockMvcBuilder to load infrastructure equivalent to the WebMvc Java config, registers the given controller(s), and creates an instance of MockMvc to handle requests:spring-doc.cn
		MockMvcWebTestClient.bindToController(new TestController()).build();
val client = MockMvcWebTestClient.bindToController(TestController()).build()
Bind to ApplicationContext
This setup allows you to load Spring configuration with Spring MVC or Spring WebFlux infrastructure and controller declarations and use it to handle requests via mock request and response objects, without a running server.spring-doc.cn
For WebFlux, use the following where the Spring ApplicationContext is passed to WebHttpHandlerBuilder to create the WebHandler chain to handle requests:spring-doc.cn
@SpringJUnitConfig(WebConfig.class) (1)
class MyTests {
	WebTestClient client;
	@BeforeEach
	void setUp(ApplicationContext context) {  (2)
		client = WebTestClient.bindToApplicationContext(context).build(); (3)
1 Specify the configuration to load
2 Inject the configuration
3 Create the WebTestClient
@SpringJUnitConfig(WebConfig::class) (1)
class MyTests {
	lateinit var client: WebTestClient
	@BeforeEach
	fun setUp(context: ApplicationContext) { (2)
		client = WebTestClient.bindToApplicationContext(context).build() (3)
For Spring MVC, use the following where the Spring ApplicationContext is passed to MockMvcBuilders.webAppContextSetup to create a MockMvc instance to handle requests:spring-doc.cn
@ExtendWith(SpringExtension.class)
@WebAppConfiguration("classpath:META-INF/web-resources") (1)
@ContextHierarchy({
	@ContextConfiguration(classes = RootConfig.class),
	@ContextConfiguration(classes = WebConfig.class)
class MyTests {
	@Autowired
	WebApplicationContext wac; (2)
	@BeforeEach
	void setUp() {
		client = MockMvcWebTestClient.bindToApplicationContext(this.wac).build(); (3)
@ContextHierarchy({
class MyTests {
	@Autowired
	lateinit var wac: WebApplicationContext; (2)
	@BeforeEach
	fun setUp() { (2)
		client = MockMvcWebTestClient.bindToApplicationContext(wac).build() (3)
Bind to Router Function
This setup allows you to test functional endpoints via mock request and response objects, without a running server.spring-doc.cn
For WebFlux, use the following which delegates to RouterFunctions.toWebHandler to create a server setup to handle requests:spring-doc.cn
RouterFunction<?> route = ...
client = WebTestClient.bindToRouterFunction(route).build();
val route: RouterFunction<*> = ...
val client = WebTestClient.bindToRouterFunction(route).build()
For Spring MVC there are currently no options to test WebMvc functional endpoints.spring-doc.cn
Bind to Server
This setup connects to a running server to perform full, end-to-end HTTP tests:spring-doc.cn
client = WebTestClient.bindToServer().baseUrl("http://localhost:8080").build();
Client Config
In addition to the server setup options described earlier, you can also configure client options, including base URL, default headers, client filters, and others. These options are readily available following bindToServer(). For all other configuration options, you need to use configureClient() to transition from server to client configuration, as follows:spring-doc.cn
client = WebTestClient.bindToController(new TestController())
		.configureClient()
		.baseUrl("/test")
		.configureClient()
		.baseUrl("/test")
		.build()
Writing Tests
WebTestClient provides an API identical to WebClient up to the point of performing a request by using exchange(). See the WebClient documentation for examples on how to prepare a request with any content including form data, multipart data, and more.spring-doc.cn
After the call to exchange(), WebTestClient diverges from the WebClient and instead continues with a workflow to verify responses.spring-doc.cn
To assert the response status and headers, use the following:spring-doc.cn
client.get().uri("/persons/1")
	.accept(MediaType.APPLICATION_JSON)
	.exchange()
	.expectStatus().isOk()
	.expectHeader().contentType(MediaType.APPLICATION_JSON);
	.exchange()
If you would like for all expectations to be asserted even if one of them fails, you can use expectAll(..) instead of multiple chained expect*(..) calls. This feature is similar to the soft assertions support in AssertJ and the assertAll() support in JUnit Jupiter.spring-doc.cn
	.exchange()
	.expectAll(
		spec -> spec.expectStatus().isOk(),
		spec -> spec.expectHeader().contentType(MediaType.APPLICATION_JSON)
	.exchange()
	.expectAll(
		{ spec -> spec.expectStatus().isOk() },
		{ spec -> spec.expectHeader().contentType(MediaType.APPLICATION_JSON) }
You can then choose to decode the response body through one of the following:spring-doc.cn
And perform assertions on the resulting higher level Object(s):spring-doc.cn
client.get().uri("/persons")
		.exchange()
		.expectBodyList(Person.class).hasSize(3).contains(person);
import org.springframework.test.web.reactive.server.expectBodyList
		.exchange()
		.expectBodyList<Person>().hasSize(3).contains(person)
If the built-in assertions are insufficient, you can consume the object instead and perform any other assertions:spring-doc.cn
		.exchange()
		.expectBody(Person.class)
		.consumeWith(result -> {
			// custom assertions (e.g. AssertJ)...
		.exchange()
		.expectBody<Person>()
		.consumeWith {
Or you can exit the workflow and obtain an EntityExchangeResult:spring-doc.cn
EntityExchangeResult<Person> result = client.get().uri("/persons/1")
		.exchange()
		.returnResult();
val result = client.get().uri("/persons/1")
		.exchange()
		.returnResult()
When you need to decode to a target type with generics, look for the overloaded methods that accept ParameterizedTypeReference instead of Class<T>.
No Content
If the response is not expected to have content, you can assert that as follows:spring-doc.cn
client.post().uri("/persons")
		.body(personMono, Person.class)
		.exchange()
		.expectStatus().isCreated()
		.expectBody().isEmpty();
		.bodyValue(person)
		.exchange()
If you want to ignore the response content, the following releases the content without any assertions:spring-doc.cn
client.get().uri("/persons/123")
		.exchange()
		.expectStatus().isNotFound()
		.expectBody(Void.class);
		.exchange()
		.expectBody<Unit>()
JSON Content
You can use expectBody() without a target type to perform assertions on the raw content rather than through higher level Object(s).spring-doc.cn
To verify the full JSON content with JSONAssert:spring-doc.cn
		.exchange()
		.expectBody()
		.json("{\"name\":\"Jane\"}")
		.exchange()
		.expectBody()
To verify JSON content with JSONPath:spring-doc.cn
		.exchange()
		.expectBody()
		.jsonPath("$[0].name").isEqualTo("Jane")
		.jsonPath("$[1].name").isEqualTo("Jason");
		.exchange()
		.expectBody()
Streaming Responses
To test potentially infinite streams such as "text/event-stream" or "application/x-ndjson", start by verifying the response status and headers, and then obtain a FluxExchangeResult:spring-doc.cn
FluxExchangeResult<MyEvent> result = client.get().uri("/events")
		.accept(TEXT_EVENT_STREAM)
		.exchange()
		.returnResult(MyEvent.class);
import org.springframework.test.web.reactive.server.returnResult
val result = client.get().uri("/events")
		.exchange()
		.returnResult<MyEvent>()
Now you’re ready to consume the response stream with StepVerifier from reactor-test:spring-doc.cn
Flux<Event> eventFlux = result.getResponseBody();
StepVerifier.create(eventFlux)
		.expectNext(person)
		.expectNextCount(4)
		.consumeNextWith(p -> ...)
		.thenCancel()
		.verify();
val eventFlux = result.getResponseBody()
		.expectNext(person)
		.expectNextCount(4)
		.consumeNextWith { p -> ... }
		.thenCancel()
		.verify()
MockMvc Assertions
WebTestClient is an HTTP client and as such it can only verify what is in the client response including status, headers, and body.spring-doc.cn
When testing a Spring MVC application with a MockMvc server setup, you have the extra choice to perform further assertions on the server response. To do that start by obtaining an ExchangeResult after asserting the body:spring-doc.cn
// For a response with a body
		.exchange()
		.returnResult();
// For a response without a body
EntityExchangeResult<Void> result = client.get().uri("/path")
		.exchange()
		.exchange()
		.returnResult()
val result = client.get().uri("/path")
		.exchange()
Then switch to MockMvc server response assertions:spring-doc.cn
MockMvcWebTestClient.resultActionsFor(result)
		.andExpect(model().attribute("integer", 3))
		.andExpect(model().attribute("string", "a string value"));
