This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Testing Client Applications
You can use client-side tests to test code that internally uses the RestTemplate
. The
idea is to declare expected requests and to provide “stub” responses so that you can
focus on testing the code in isolation (that is, without running a server). The following
example shows how to do so:
Java
Kotlin
RestTemplate restTemplate = new RestTemplate();
MockRestServiceServer mockServer = MockRestServiceServer.bindTo(restTemplate).build();
mockServer.expect(requestTo("/greeting")).andRespond(withSuccess());
// Test code that uses the above RestTemplate ...
mockServer.verify();
val restTemplate = RestTemplate()
val mockServer = MockRestServiceServer.bindTo(restTemplate).build()
mockServer.verify()
In the preceding example, MockRestServiceServer
(the central class for client-side REST
tests) configures the RestTemplate
with a custom ClientHttpRequestFactory
that
asserts actual requests against expectations and returns “stub” responses. In this
case, we expect a request to /greeting
and want to return a 200 response with
text/plain
content. We can define additional expected requests and stub responses as
needed. When we define expected requests and stub responses, the RestTemplate
can be
used in client-side code as usual. At the end of testing, mockServer.verify()
can be
used to verify that all expectations have been satisfied.
By default, requests are expected in the order in which expectations were declared. You
can set the ignoreExpectOrder
option when building the server, in which case all
expectations are checked (in order) to find a match for a given request. That means
requests are allowed to come in any order. The following example uses ignoreExpectOrder
Java
Kotlin
server = MockRestServiceServer.bindTo(restTemplate).ignoreExpectOrder(true).build();
Even with unordered requests by default, each request is allowed to run once only.
The expect
method provides an overloaded variant that accepts an ExpectedCount
argument that specifies a count range (for example, once
, manyTimes
, max
, min
between
, and so on). The following example uses times
Java
Kotlin
mockServer.expect(times(2), requestTo("/something")).andRespond(withSuccess());
mockServer.expect(times(3), requestTo("/somewhere")).andRespond(withSuccess());
mockServer.verify()
Note that, when ignoreExpectOrder
is not set (the default), and, therefore, requests
are expected in order of declaration, then that order applies only to the first of any
expected request. For example if "/something" is expected two times followed by
"/somewhere" three times, then there should be a request to "/something" before there is
a request to "/somewhere", but, aside from that subsequent "/something" and "/somewhere",
requests can come at any time.
As an alternative to all of the above, the client-side test support also provides a
implementation that you can configure into a RestTemplate
to
bind it to a MockMvc
instance. That allows processing requests using actual server-side
logic but without running a server. The following example shows how to do so:
Java
Kotlin
MockMvc mockMvc = MockMvcBuilders.webAppContextSetup(this.wac).build();
this.restTemplate = new RestTemplate(new MockMvcClientHttpRequestFactory(mockMvc));
val mockMvc = MockMvcBuilders.webAppContextSetup(this.wac).build()
restTemplate = RestTemplate(MockMvcClientHttpRequestFactory(mockMvc))
In some cases it may be necessary to perform an actual call to a remote service instead
of mocking the response. The following example shows how to do that through
ExecutingResponseCreator
Java
Kotlin
// Create ExecutingResponseCreator with the original request factory
ExecutingResponseCreator withActualResponse = new ExecutingResponseCreator(restTemplate.getRequestFactory());
mockServer.expect(requestTo("/profile")).andRespond(withSuccess());
mockServer.expect(requestTo("/quoteOfTheDay")).andRespond(withActualResponse);
val withActualResponse = new ExecutingResponseCreator(restTemplate.getRequestFactory())
mockServer.verify()
In the preceding example, we create the ExecutingResponseCreator
using the
from the RestTemplate
before MockRestServiceServer
replaces
it with a different one that mocks responses.
Then we define expectations with two kinds of responses:
a stub
200
response for the/profile
endpoint (no actual request will be executed) -
a response obtained through a call to the
/quoteOfTheDay
endpoint
In the second case, the request is executed through the ClientHttpRequestFactory
that was
captured earlier. This generates a response that could e.g. come from an actual remote server,
depending on how the RestTemplate
was originally configured.
Static Imports
As with server-side tests, the fluent API for client-side tests requires a few static
imports. Those are easy to find by searching for MockRest*
. Eclipse users should add
MockRestRequestMatchers.*
and MockRestResponseCreators.*
as
“favorite static members” in the Eclipse preferences under Java → Editor → Content
Assist → Favorites. That allows using content assist after typing the first character of
the static method name. Other IDEs (such IntelliJ) may not require any additional
configuration. Check for the support for code completion on static members.
Further Examples of Client-side REST Tests
Spring MVC Test’s own tests include example tests of client-side REST tests.
