This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Notifications
Spring’s JMX offering includes comprehensive support for JMX notifications.
Registering Listeners for Notifications
Spring’s JMX support makes it easy to register any number of
NotificationListeners
with any number of MBeans (this includes MBeans exported by
Spring’s MBeanExporter
and MBeans registered through some other mechanism). For
example, consider the scenario where one would like to be informed (through a
Notification
) each and every time an attribute of a target MBean changes. The following
example writes notifications to the console:
package com.example;
import javax.management.AttributeChangeNotification;
import javax.management.Notification;
import javax.management.NotificationFilter;
import javax.management.NotificationListener;
public class ConsoleLoggingNotificationListener
implements NotificationListener, NotificationFilter {
public void handleNotification(Notification notification, Object handback) {
System.out.println(notification);
System.out.println(handback);
public boolean isNotificationEnabled(Notification notification) {
return AttributeChangeNotification.class.isAssignableFrom(notification.getClass());
The following example adds ConsoleLoggingNotificationListener
(defined in the preceding
example) to notificationListenerMappings
<beans>
<bean id="exporter" class="org.springframework.jmx.export.MBeanExporter">
<property name="beans">
<map>
<entry key="bean:name=testBean1" value-ref="testBean"/>
</map>
</property>
<property name="notificationListenerMappings">
<map>
<entry key="bean:name=testBean1">
<bean class="com.example.ConsoleLoggingNotificationListener"/>
</entry>
</map>
</property>
</bean>
<bean id="testBean" class="org.springframework.jmx.JmxTestBean">
<property name="name" value="TEST"/>
<property name="age" value="100"/>
</bean>
</beans>
With the preceding configuration in place, every time a JMX Notification
is broadcast from
the target MBean (bean:name=testBean1
), the ConsoleLoggingNotificationListener
bean
that was registered as a listener through the notificationListenerMappings
property is
notified. The ConsoleLoggingNotificationListener
bean can then take whatever action
it deems appropriate in response to the Notification
You can also use straight bean names as the link between exported beans and listeners, as the following example shows:
<beans>
<map>
</map>
</property>
<map>
<entry key="testBean">
</entry>
</map>
</property>
</bean>
</bean>
</beans>
If you want to register a single NotificationListener
instance for all of the beans
that the enclosing MBeanExporter
exports, you can use the special wildcard (*
as the key for an entry in the notificationListenerMappings
property
map, as the following example shows:
<map>
<entry key="*">
</entry>
</map>
</property>
If you need to do the inverse (that is, register a number of distinct listeners against
an MBean), you must instead use the notificationListeners
list property (in
preference to the notificationListenerMappings
property). This time, instead of
configuring a NotificationListener
for a single MBean, we configure
NotificationListenerBean
instances. A NotificationListenerBean
encapsulates a
and the ObjectName
(or ObjectNames
) that it is to be
registered against in an MBeanServer
. The NotificationListenerBean
also encapsulates
a number of other properties, such as a NotificationFilter
and an arbitrary handback
object that can be used in advanced JMX notification scenarios.
The configuration when using NotificationListenerBean
instances is not wildly
different to what was presented previously, as the following example shows:
<beans>
<map>
</map>
</property>
<property name="notificationListeners">
<list>
<bean class="org.springframework.jmx.export.NotificationListenerBean">
<constructor-arg>
</constructor-arg>
<property name="mappedObjectNames">
<list>
<value>bean:name=testBean1</value>
</list>
</property>
</bean>
</list>
</property>
</bean>
</bean>
</beans>
The preceding example is equivalent to the first notification example. Assume, then, that
we want to be given a handback object every time a Notification
is raised and that
we also want to filter out extraneous Notifications
by supplying a
NotificationFilter
. The following example accomplishes these goals:
<beans>
<map>
<entry key="bean:name=testBean1" value-ref="testBean1"/>
<entry key="bean:name=testBean2" value-ref="testBean2"/>
</map>
</property>
<list>
<constructor-arg ref="customerNotificationListener"/>
<list>
<!-- handles notifications from two distinct MBeans -->
<value>bean:name=testBean2</value>
</list>
</property>
<property name="handback">
<bean class="java.lang.String">
<constructor-arg value="This could be anything..."/>
</bean>
</property>
<property name="notificationFilter" ref="customerNotificationListener"/>
</bean>
</list>
</property>
</bean>
<!-- implements both the NotificationListener and NotificationFilter interfaces -->
<bean id="customerNotificationListener" class="com.example.ConsoleLoggingNotificationListener"/>
<bean id="testBean1" class="org.springframework.jmx.JmxTestBean">
</bean>
<bean id="testBean2" class="org.springframework.jmx.JmxTestBean">
<property name="name" value="ANOTHER TEST"/>
<property name="age" value="200"/>
</bean>
</beans>
(For a full discussion of what a handback object is and,
indeed, what a NotificationFilter
is, see the section of the JMX
specification (1.2) entitled 'The JMX Notification Model'.)
Publishing Notifications
Spring provides support not only for registering to receive Notifications
but also
for publishing Notifications
This section is really only relevant to Spring-managed beans that have
been exposed as MBeans through an MBeanExporter . Any existing user-defined MBeans should
use the standard JMX APIs for notification publication.
The key interface in Spring’s JMX notification publication support is the
NotificationPublisher
interface (defined in the
org.springframework.jmx.export.notification
package). Any bean that is going to be
exported as an MBean through an MBeanExporter
instance can implement the related
NotificationPublisherAware
interface to gain access to a NotificationPublisher
instance. The NotificationPublisherAware
interface supplies an instance of a
to the implementing bean through a simple setter method,
which the bean can then use to publish Notifications
As stated in the javadoc of the
interface, managed beans that publish events through the NotificationPublisher
mechanism are not responsible for the state management of notification listeners.
Spring’s JMX support takes care of handling all the JMX infrastructure issues.
All you need to do, as an application developer, is implement the
interface and start publishing events by using the
supplied NotificationPublisher
instance. Note that the NotificationPublisher
is set after the managed bean has been registered with an MBeanServer
Using a NotificationPublisher
instance is quite straightforward. You create a JMX
Notification
instance (or an instance of an appropriate Notification
subclass),
populate the notification with the data pertinent to the event that is to be
published, and invoke the sendNotification(Notification)
on the
instance, passing in the Notification
In the following example, exported instances of the JmxTestBean
publish a
NotificationEvent
every time the add(int, int)
operation is invoked:
package org.springframework.jmx;
import org.springframework.jmx.export.notification.NotificationPublisherAware;
import org.springframework.jmx.export.notification.NotificationPublisher;
public class JmxTestBean implements IJmxTestBean, NotificationPublisherAware {
private String name;
private int age;
private boolean isSuperman;
private NotificationPublisher publisher;
// other getters and setters omitted for clarity
public int add(int x, int y) {
int answer = x + y;
this.publisher.sendNotification(new Notification("add", this, 0));
return answer;
public void dontExposeMe() {
throw new RuntimeException();
public void setNotificationPublisher(NotificationPublisher notificationPublisher) {
this.publisher = notificationPublisher;
interface and the machinery to get it all working is one of
the nicer features of Spring’s JMX support. It does, however, come with the price tag of
coupling your classes to both Spring and JMX. As always, the advice here is to be
pragmatic. If you need the functionality offered by the NotificationPublisher
and
you can accept the coupling to both Spring and JMX, then do so.
