This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Validation
By default, if Bean Validation is present on the classpath (for example, Hibernate Validator), the LocalValidatorFactoryBean is registered as a global Validator for use with @Valid and @Validated on controller method arguments.spring-doc.cn
In Java configuration, you can customize the global Validator instance, as the following example shows:spring-doc.cn
@EnableWebMvc
	public Validator getValidator() {
@EnableWebMvc
	override fun getValidator(): Validator {
The following example shows how to achieve the same configuration in XML:spring-doc.cn
	xmlns:mvc="http://www.springframework.org/schema/mvc"
	xsi:schemaLocation="
		https://www.springframework.org/schema/mvc/spring-mvc.xsd">
	<mvc:annotation-driven validator="globalValidator"/>
</beans>
Note that you can also register Validator implementations locally, as the following example shows:spring-doc.cn
@Controller
public class MyController {
	@InitBinder
	protected void initBinder(WebDataBinder binder) {
		binder.addValidators(new FooValidator());
@Controller
	@InitBinder
	protected fun initBinder(binder: WebDataBinder) {
		binder.addValidators(FooValidator())
If you need to have a LocalValidatorFactoryBean injected somewhere, create a bean and mark it with @Primary in order to avoid conflict with the one declared in the MVC configuration.
