This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Enabling @AspectJ Support
To use @AspectJ aspects in a Spring configuration, you need to enable Spring support for configuring Spring AOP based on @AspectJ aspects and auto-proxying beans based on whether or not they are advised by those aspects. By auto-proxying, we mean that, if Spring determines that a bean is advised by one or more aspects, it automatically generates a proxy for that bean to intercept method invocations and ensures that advice is run as needed.
The @AspectJ support can be enabled with XML- or Java-style configuration. In either
case, you also need to ensure that AspectJ’s aspectjweaver.jar
library is on the
classpath of your application (version 1.9 or later). This library is available in the
lib
directory of an AspectJ distribution or from the Maven Central repository.
Enabling @AspectJ Support with Java Configuration
To enable @AspectJ support with Java @Configuration
, add the @EnableAspectJAutoProxy
annotation, as the following example shows:
Java
Kotlin
public class AppConfig {
class AppConfig
Enabling @AspectJ Support with XML Configuration
To enable @AspectJ support with XML-based configuration, use the aop:aspectj-autoproxy
element, as the following example shows:
<aop:aspectj-autoproxy/>
This assumes that you use schema support as described in
XML Schema-based configuration.
See the AOP schema for how to
import the tags in the aop
namespace.
