This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Resources
This chapter covers how Spring handles resources and how you can work with resources in Spring. It includes the following topics:
Introduction
Java’s standard java.net.URL
class and standard handlers for various URL prefixes,
unfortunately, are not quite adequate enough for all access to low-level resources. For
example, there is no standardized URL
implementation that may be used to access a
resource that needs to be obtained from the classpath or relative to a
ServletContext
. While it is possible to register new handlers for specialized URL
prefixes (similar to existing handlers for prefixes such as http:
), this is generally
quite complicated, and the URL
interface still lacks some desirable functionality,
such as a method to check for the existence of the resource being pointed to.
The Resource
Interface
Spring’s Resource
interface located in the org.springframework.core.io.
package is
meant to be a more capable interface for abstracting access to low-level resources. The
following listing provides an overview of the Resource
interface. See the
Resource
javadoc for further details.
public interface Resource extends InputStreamSource {
boolean exists();
boolean isReadable();
boolean isOpen();
boolean isFile();
URL getURL() throws IOException;
URI getURI() throws IOException;
File getFile() throws IOException;
ReadableByteChannel readableChannel() throws IOException;
long contentLength() throws IOException;
long lastModified() throws IOException;
Resource createRelative(String relativePath) throws IOException;
String getFilename();
String getDescription();
As the definition of the Resource
interface shows, it extends the InputStreamSource
interface. The following listing shows the definition of the InputStreamSource
interface:
public interface InputStreamSource {
InputStream getInputStream() throws IOException;
Some of the most important methods from the Resource
interface are:
getInputStream()
: Locates and opens the resource, returning anInputStream
for reading from the resource. It is expected that each invocation returns a freshInputStream
. It is the responsibility of the caller to close the stream. -
exists()
: Returns aboolean
indicating whether this resource actually exists in physical form. -
isOpen()
: Returns aboolean
indicating whether this resource represents a handle with an open stream. Iftrue
, theInputStream
cannot be read multiple times and must be read once only and then closed to avoid resource leaks. Returnsfalse
for all usual resource implementations, with the exception ofInputStreamResource
getDescription()
: Returns a description for this resource, to be used for error output when working with the resource. This is often the fully qualified file name or the actual URL of the resource.
Other methods let you obtain an actual URL
or File
object representing the
resource (if the underlying implementation is compatible and supports that
functionality).
Some implementations of the Resource
interface also implement the extended
WritableResource
interface
for a resource that supports writing to it.
Spring itself uses the Resource
abstraction extensively, as an argument type in
many method signatures when a resource is needed. Other methods in some Spring APIs
(such as the constructors to various ApplicationContext
implementations) take a
String
which in unadorned or simple form is used to create a Resource
appropriate to
that context implementation or, via special prefixes on the String
path, let the
caller specify that a specific Resource
implementation must be created and used.
While the Resource
interface is used a lot with Spring and by Spring, it is actually
very convenient to use as a general utility class by itself in your own code, for access
to resources, even when your code does not know or care about any other parts of Spring.
While this couples your code to Spring, it really only couples it to this small set of
utility classes, which serves as a more capable replacement for URL
and can be
considered equivalent to any other library you would use for this purpose.
The Resource abstraction does not replace functionality. It wraps it where
possible. For example, a UrlResource wraps a URL and uses the wrapped URL to do its
work.
Built-in Resource
Implementations
Spring includes several built-in Resource
implementations:
For a complete list of Resource
implementations available in Spring, consult the
"All Known Implementing Classes" section of the
Resource
javadoc.
UrlResource
UrlResource
wraps a java.net.URL
and can be used to access any object that is
normally accessible with a URL, such as files, an HTTPS target, an FTP target, and
others. All URLs have a standardized String
representation, such that appropriate
standardized prefixes are used to indicate one URL type from another. This includes
file:
for accessing filesystem paths, https:
for accessing resources through the
HTTPS protocol, ftp:
for accessing resources through FTP, and others.
A UrlResource
is created by Java code by explicitly using the UrlResource
constructor
but is often created implicitly when you call an API method that takes a String
argument meant to represent a path. For the latter case, a JavaBeans PropertyEditor
ultimately decides which type of Resource
to create. If the path string contains a
well-known (to property editor, that is) prefix (such as classpath:
), it creates an
appropriate specialized Resource
for that prefix. However, if it does not recognize the
prefix, it assumes the string is a standard URL string and creates a UrlResource
ClassPathResource
This class represents a resource that should be obtained from the classpath. It uses either the thread context class loader, a given class loader, or a given class for loading resources.
This Resource
implementation supports resolution as a java.io.File
if the class path
resource resides in the file system but not for classpath resources that reside in a
jar and have not been expanded (by the servlet engine or whatever the environment is)
to the filesystem. To address this, the various Resource
implementations always support
resolution as a java.net.URL
A ClassPathResource
is created by Java code by explicitly using the ClassPathResource
constructor but is often created implicitly when you call an API method that takes a
String
PropertyEditor
recognizes the special prefix, classpath:
, on the string path and
creates a ClassPathResource
in that case.
FileSystemResource
This is a Resource
implementation for java.io.File
handles. It also supports
java.nio.file.Path
handles, applying Spring’s standard String-based path
transformations but performing all operations via the java.nio.file.Files
API. For pure
java.nio.path.Path
based support use a PathResource
instead. FileSystemResource
supports resolution as a File
and as a URL
PathResource
This is a Resource
implementation for java.nio.file.Path
handles, performing all
operations and transformations via the Path
API. It supports resolution as a File
and
as a URL
and also implements the extended WritableResource
interface. PathResource
is effectively a pure java.nio.path.Path
based alternative to FileSystemResource
with
different createRelative
behavior.
ServletContextResource
This is a Resource
implementation for ServletContext
resources that interprets
relative paths within the relevant web application’s root directory.
It always supports stream access and URL access but allows java.io.File
access only
when the web application archive is expanded and the resource is physically on the
filesystem. Whether or not it is expanded and on the filesystem or accessed
directly from the JAR or somewhere else like a database (which is conceivable) is actually
dependent on the Servlet container.
InputStreamResource
An InputStreamResource
is a Resource
implementation for a given InputStream
. It
should be used only if no specific Resource
implementation is applicable. In
particular, prefer ByteArrayResource
or any of the file-based Resource
implementations where possible.
In contrast to other Resource
implementations, this is a descriptor for an
already-opened resource. Therefore, it returns true
from isOpen()
. Do not use it if
you need to keep the resource descriptor somewhere or if you need to read a stream
multiple times.
The ResourceLoader
Interface
The ResourceLoader
interface is meant to be implemented by objects that can return
(that is, load) Resource
instances. The following listing shows the ResourceLoader
interface definition:
public interface ResourceLoader {
Resource getResource(String location);
ClassLoader getClassLoader();
All application contexts implement the ResourceLoader
interface. Therefore, all
application contexts may be used to obtain Resource
instances.
When you call getResource()
on a specific application context, and the location path
specified doesn’t have a specific prefix, you get back a Resource
type that is
appropriate to that particular application context. For example, assume the following
snippet of code was run against a ClassPathXmlApplicationContext
instance:
Java
Kotlin
Resource template = ctx.getResource("some/resource/path/myTemplate.txt");
val template = ctx.getResource("some/resource/path/myTemplate.txt")
Against a ClassPathXmlApplicationContext
, that code returns a ClassPathResource
. If
the same method were run against a FileSystemXmlApplicationContext
instance, it would
return a FileSystemResource
. For a WebApplicationContext
, it would return a
. It would similarly return appropriate objects for each context.
As a result, you can load resources in a fashion appropriate to the particular application context.
On the other hand, you may also force ClassPathResource
to be used, regardless of the
application context type, by specifying the special classpath:
prefix, as the following
example shows:
Java
Kotlin
Resource template = ctx.getResource("classpath:some/resource/path/myTemplate.txt");
val template = ctx.getResource("classpath:some/resource/path/myTemplate.txt")
Similarly, you can force a UrlResource
to be used by specifying any of the standard
java.net.URL
prefixes. The following examples use the file
and https
prefixes:
Java
Kotlin
Resource template = ctx.getResource("file:///some/resource/path/myTemplate.txt");
val template = ctx.getResource("file:///some/resource/path/myTemplate.txt")
Java
Kotlin
Resource template = ctx.getResource("https://myhost.com/resource/path/myTemplate.txt");
val template = ctx.getResource("https://myhost.com/resource/path/myTemplate.txt")
The following table summarizes the strategy for converting String
objects to Resource
objects:
Prefix | Example | Explanation |
classpath: |
Loaded from the classpath. |
file: |
Loaded as a |
https: |
Loaded as a |
(none) |
Depends on the underlying |
The ResourcePatternResolver
Interface
interface is an extension to the ResourceLoader
interface
which defines a strategy for resolving a location pattern (for example, an Ant-style path
pattern) into Resource
objects.
public interface ResourcePatternResolver extends ResourceLoader {
String CLASSPATH_ALL_URL_PREFIX = "classpath*:";
Resource[] getResources(String locationPattern) throws IOException;
As can be seen above, this interface also defines a special classpath*:
resource prefix
for all matching resources from the class path. Note that the resource location is
expected to be a path without placeholders in this case — for example,
classpath*:/config/beans.xml
. JAR files or different directories in the class path can
contain multiple files with the same path and the same name. See
Wildcards in Application Context Constructor Resource Paths and its subsections for further details
on wildcard support with the classpath*:
resource prefix.
A passed-in ResourceLoader
(for example, one supplied via
ResourceLoaderAware
semantics) can be checked whether
it implements this extended interface too.
PathMatchingResourcePatternResolver
is a standalone implementation that is usable
outside an ApplicationContext
and is also used by ResourceArrayPropertyEditor
for
populating Resource[]
bean properties. PathMatchingResourcePatternResolver
is able to
resolve a specified resource location path into one or more matching Resource
objects.
The source path may be a simple path which has a one-to-one mapping to a target
Resource
, or alternatively may contain the special classpath*:
prefix and/or internal
Ant-style regular expressions (matched using Spring’s
org.springframework.util.AntPathMatcher
utility). Both of the latter are effectively
wildcards.
The default |
The ResourceLoaderAware
Interface
interface is a special callback interface which identifies
components that expect to be provided a ResourceLoader
reference. The following listing
shows the definition of the ResourceLoaderAware
interface:
public interface ResourceLoaderAware {
void setResourceLoader(ResourceLoader resourceLoader);
When a class implements ResourceLoaderAware
and is deployed into an application context
(as a Spring-managed bean), it is recognized as ResourceLoaderAware
by the application
context. The application context then invokes setResourceLoader(ResourceLoader)
supplying itself as the argument (remember, all application contexts in Spring implement
the ResourceLoader
interface).
Since an ApplicationContext
is a ResourceLoader
, the bean could also implement the
ApplicationContextAware
interface and use the supplied application context directly to
load resources. However, in general, it is better to use the specialized ResourceLoader
interface if that is all you need. The code would be coupled only to the resource loading
interface (which can be considered a utility interface) and not to the whole Spring
ApplicationContext
interface.
In application components, you may also rely upon autowiring of the ResourceLoader
as
an alternative to implementing the ResourceLoaderAware
interface. The traditional
constructor
and byType
autowiring modes (as described in Autowiring Collaborators)
are capable of providing a ResourceLoader
for either a constructor argument or a
setter method parameter, respectively. For more flexibility (including the ability to
autowire fields and multiple parameter methods), consider using the annotation-based
autowiring features. In that case, the ResourceLoader
is autowired into a field,
constructor argument, or method parameter that expects the ResourceLoader
type as long
as the field, constructor, or method in question carries the @Autowired
annotation.
For more information, see Using @Autowired
To load one or more Resource objects for a resource path that contains wildcards
or makes use of the special classpath*: resource prefix, consider having an instance of
ResourcePatternResolver autowired into your
application components instead of ResourceLoader .
Resources as Dependencies
If the bean itself is going to determine and supply the resource path through some sort
of dynamic process, it probably makes sense for the bean to use the ResourceLoader
or
interface to load resources. For example, consider the loading
of a template of some sort, where the specific resource that is needed depends on the
role of the user. If the resources are static, it makes sense to eliminate the use of the
ResourceLoader
interface (or ResourcePatternResolver
interface) completely, have the
bean expose the Resource
properties it needs, and expect them to be injected into it.
What makes it trivial to then inject these properties is that all application contexts
register and use a special JavaBeans PropertyEditor
, which can convert String
paths
to Resource
objects. For example, the following MyBean
class has a template
property of type Resource
Java
Kotlin
public class MyBean {
private Resource template;
public setTemplate(Resource template) {
this.template = template;
class MyBean(var template: Resource)
In an XML configuration file, the template
property can be configured with a simple
string for that resource, as the following example shows:
<bean id="myBean" class="example.MyBean">
<property name="template" value="some/resource/path/myTemplate.txt"/>
</bean>
Note that the resource path has no prefix. Consequently, because the application context
itself is going to be used as the ResourceLoader
, the resource is loaded through a
ClassPathResource
, a FileSystemResource
, or a ServletContextResource
, depending on
the exact type of the application context.
If you need to force a specific Resource
type to be used, you can use a prefix. The
following two examples show how to force a ClassPathResource
and a UrlResource
(the
latter being used to access a file in the filesystem):
<property name="template" value="classpath:some/resource/path/myTemplate.txt">
<property name="template" value="file:///some/resource/path/myTemplate.txt"/>
If the MyBean
class is refactored for use with annotation-driven configuration, the
path to myTemplate.txt
can be stored under a key named template.path
— for example,
in a properties file made available to the Spring Environment
(see
Environment Abstraction). The template path can then be referenced via the @Value
annotation using a property placeholder (see Using @Value
). Spring will
retrieve the value of the template path as a string, and a special PropertyEditor
will
convert the string to a Resource
object to be injected into the MyBean
constructor.
The following example demonstrates how to achieve this.
Java
Kotlin
@Component
private final Resource template;
public MyBean(@Value("${template.path}") Resource template) {
@Component
class MyBean(@Value("\${template.path}") private val template: Resource)
If we want to support multiple templates discovered under the same path in multiple
locations in the classpath — for example, in multiple jars in the classpath — we can
use the special classpath*:
prefix and wildcarding to define a templates.path
key as
classpath*:/config/templates/*.txt
. If we redefine the MyBean
class as follows,
Spring will convert the template path pattern into an array of Resource
objects that
can be injected into the MyBean
constructor.
Java
Kotlin
@Component
private final Resource[] templates;
public MyBean(@Value("${templates.path}") Resource[] templates) {
this.templates = templates;
@Component
class MyBean(@Value("\${templates.path}") private val templates: Resource[])
Application Contexts and Resource Paths
This section covers how to create application contexts with resources, including shortcuts that work with XML, how to use wildcards, and other details.
Constructing Application Contexts
An application context constructor (for a specific application context type) generally takes a string or array of strings as the location paths of the resources, such as XML files that make up the definition of the context.
When such a location path does not have a prefix, the specific Resource
type built from
that path and used to load the bean definitions depends on and is appropriate to the
specific application context. For example, consider the following example, which creates a
Java
Kotlin
ApplicationContext ctx = new ClassPathXmlApplicationContext("conf/appContext.xml");
val ctx = ClassPathXmlApplicationContext("conf/appContext.xml")
The bean definitions are loaded from the classpath, because a ClassPathResource
is
used. However, consider the following example, which creates a FileSystemXmlApplicationContext
Java
Kotlin
new FileSystemXmlApplicationContext("conf/appContext.xml");
val ctx = FileSystemXmlApplicationContext("conf/appContext.xml")
Now the bean definitions are loaded from a filesystem location (in this case, relative to the current working directory).
Note that the use of the special classpath
prefix or a standard URL prefix on the
location path overrides the default type of Resource
created to load the bean
definitions. Consider the following example:
Java
Kotlin
new FileSystemXmlApplicationContext("classpath:conf/appContext.xml");
val ctx = FileSystemXmlApplicationContext("classpath:conf/appContext.xml")
Using FileSystemXmlApplicationContext
loads the bean definitions from the classpath.
However, it is still a FileSystemXmlApplicationContext
. If it is subsequently used as a
ResourceLoader
, any unprefixed paths are still treated as filesystem paths.
Constructing ClassPathXmlApplicationContext
Instances — Shortcuts
The ClassPathXmlApplicationContext
exposes a number of constructors to enable
convenient instantiation. The basic idea is that you can supply merely a string array
that contains only the filenames of the XML files themselves (without the leading path
information) and also supply a Class
. The ClassPathXmlApplicationContext
then derives
the path information from the supplied class.
Consider the following directory layout:
com/ example/ services.xml repositories.xml MessengerService.class
The following example shows how a ClassPathXmlApplicationContext
instance composed of
the beans defined in files named services.xml
and repositories.xml
(which are on the
classpath) can be instantiated:
Java
Kotlin
new String[] {"services.xml", "repositories.xml"}, MessengerService.class);
val ctx = ClassPathXmlApplicationContext(arrayOf("services.xml", "repositories.xml"), MessengerService::class.java)
See the ClassPathXmlApplicationContext
javadoc for details on the various constructors.
The resource paths in application context constructor values may be simple paths (as
shown earlier), each of which has a one-to-one mapping to a target Resource
or,
alternately, may contain the special classpath*:
prefix or internal Ant-style patterns
(matched by using Spring’s PathMatcher
wildcards.
One use for this mechanism is when you need to do component-style application assembly. All
components can publish context definition fragments to a well-known location path, and,
when the final application context is created using the same path prefixed with
classpath*:
, all component fragments are automatically picked up.
Note that this wildcarding is specific to the use of resource paths in application context
constructors (or when you use the PathMatcher
utility class hierarchy directly) and is
resolved at construction time. It has nothing to do with the Resource
type itself.
You cannot use the classpath*:
prefix to construct an actual Resource
, as
a resource points to just one resource at a time.
Ant-style Patterns
Path locations can contain Ant-style patterns, as the following example shows:
/WEB-INF/*-context.xml com/mycompany/**/applicationContext.xml file:C:/some/path/*-context.xml classpath:com/mycompany/**/applicationContext.xml
When the path location contains an Ant-style pattern, the resolver follows a more complex
procedure to try to resolve the wildcard. It produces a Resource
for the path up to the
last non-wildcard segment and obtains a URL from it. If this URL is not a jar:
URL or
container-specific variant (such as zip:
in WebLogic, wsjar
in WebSphere, and so on),
a java.io.File
is obtained from it and used to resolve the wildcard by traversing the
filesystem. In the case of a jar URL, the resolver either gets a
java.net.JarURLConnection
from it or manually parses the jar URL and then traverses the
contents of the jar file to resolve the wildcards.
Implications on Portability
If the specified path is already a file
URL (either implicitly because the base
ResourceLoader
is a filesystem one or explicitly), wildcarding is guaranteed to
work in a completely portable fashion.
If the specified path is a classpath
location, the resolver must obtain the last
non-wildcard path segment URL by making a Classloader.getResource()
call. Since this
is just a node of the path (not the file at the end), it is actually undefined (in the
ClassLoader
javadoc) exactly what sort of a URL is returned in this case. In practice,
it is always a java.io.File
representing the directory (where the classpath resource
resolves to a filesystem location) or a jar URL of some sort (where the classpath resource
resolves to a jar location). Still, there is a portability concern on this operation.
If a jar URL is obtained for the last non-wildcard segment, the resolver must be able to
get a java.net.JarURLConnection
from it or manually parse the jar URL, to be able to
walk the contents of the jar and resolve the wildcard. This does work in most environments
but fails in others, and we strongly recommend that the wildcard resolution of resources
coming from jars be thoroughly tested in your specific environment before you rely on it.
The classpath*:
Prefix
When constructing an XML-based application context, a location string may use the
special classpath*:
prefix, as the following example shows:
Java
Kotlin
new ClassPathXmlApplicationContext("classpath*:conf/appContext.xml");
val ctx = ClassPathXmlApplicationContext("classpath*:conf/appContext.xml")
This special prefix specifies that all classpath resources that match the given name
must be obtained (internally, this essentially happens through a call to
ClassLoader.getResources(…)
) and then merged to form the final application
context definition.
The wildcard classpath relies on the getResources() method of the underlying
ClassLoader . As most application servers nowadays supply their own ClassLoader
implementation, the behavior might differ, especially when dealing with jar files. A
simple test to check if classpath* works is to use the ClassLoader to load a file from
within a jar on the classpath:
getClass().getClassLoader().getResources("<someFileInsideTheJar>") . Try this test with
files that have the same name but reside in two different locations — for example, files
with the same name and same path but in different jars on the classpath. In case an
inappropriate result is returned, check the application server documentation for settings
that might affect the ClassLoader behavior.
You can also combine the classpath*:
prefix with a PathMatcher
pattern in the
rest of the location path (for example, classpath*:META-INF/*-beans.xml
). In this
case, the resolution strategy is fairly simple: A ClassLoader.getResources()
call is
used on the last non-wildcard path segment to get all the matching resources in the
class loader hierarchy and then, off each resource, the same PathMatcher
resolution
strategy described earlier is used for the wildcard subpath.
Other Notes Relating to Wildcards
Note that classpath*:
, when combined with Ant-style patterns, only works
reliably with at least one root directory before the pattern starts, unless the actual
target files reside in the file system. This means that a pattern such as
classpath*:*.xml
might not retrieve files from the root of jar files but rather only
from the root of expanded directories.
Spring’s ability to retrieve classpath entries originates from the JDK’s
method, which only returns file system locations for an
empty string (indicating potential roots to search). Spring evaluates
URLClassLoader
runtime configuration and the java.class.path
manifest in jar files
as well, but this is not guaranteed to lead to portable behavior.
The scanning of classpath packages requires the presence of corresponding directory
entries in the classpath. When you build JARs with Ant, do not activate the On JDK 9’s module path (Jigsaw), Spring’s classpath scanning generally works as expected. Putting resources into a dedicated directory is highly recommendable here as well, avoiding the aforementioned portability problems with searching the jar file root level. |
Ant-style patterns with classpath:
resources are not guaranteed to find matching
resources if the root package to search is available in multiple classpath locations.
Consider the following example of a resource location:
com/mycompany/package1/service-context.xml
Now consider an Ant-style path that someone might use to try to find that file:
classpath:com/mycompany/**/service-context.xml
Such a resource may exist in only one location in the classpath, but when a path such as
the preceding example is used to try to resolve it, the resolver works off the (first)
URL returned by getResource("com/mycompany");
. If this base package node exists in
multiple ClassLoader
locations, the desired resource may not exist in the first
location found. Therefore, in such cases you should prefer using classpath*:
with the
same Ant-style pattern, which searches all classpath locations that contain the
com.mycompany
base package: classpath*:com/mycompany/**/service-context.xml
FileSystemResource
Caveats
A FileSystemResource
that is not attached to a FileSystemApplicationContext
(that
is, when a FileSystemApplicationContext
is not the actual ResourceLoader
) treats
absolute and relative paths as you would expect. Relative paths are relative to the
current working directory, while absolute paths are relative to the root of the
filesystem.
For backwards compatibility (historical) reasons however, this changes when the
is the ResourceLoader
. The
forces all attached FileSystemResource
instances
to treat all location paths as relative, whether they start with a leading slash or not.
In practice, this means the following examples are equivalent:
Java
Kotlin
new FileSystemXmlApplicationContext("conf/context.xml");
val ctx = FileSystemXmlApplicationContext("conf/context.xml")
Java
Kotlin
new FileSystemXmlApplicationContext("/conf/context.xml");
val ctx = FileSystemXmlApplicationContext("/conf/context.xml")
The following examples are also equivalent (even though it would make sense for them to be different, as one case is relative and the other absolute):
Java
Kotlin
FileSystemXmlApplicationContext ctx = ...;
val ctx: FileSystemXmlApplicationContext = ...
Java
Kotlin
ctx.getResource("/some/resource/path/myTemplate.txt");
In practice, if you need true absolute filesystem paths, you should avoid using
absolute paths with FileSystemResource
or FileSystemXmlApplicationContext
and
force the use of a UrlResource
by using the file:
URL prefix. The following examples
show how to do so:
Java
Kotlin
// actual context type doesn't matter, the Resource will always be UrlResource
Java
Kotlin
// force this FileSystemXmlApplicationContext to load its definition via a UrlResource
new FileSystemXmlApplicationContext("file:///conf/context.xml");
val ctx = FileSystemXmlApplicationContext("file:///conf/context.xml")
