This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
XML Marshalling
The MarshallingView uses an XML Marshaller (defined in the org.springframework.oxm package) to render the response content as XML. You can explicitly set the object to be marshalled by using a MarshallingView instance’s modelKey bean property. Alternatively, the view iterates over all model properties and marshals the first type that is supported by the Marshaller. For more information on the functionality in the org.springframework.oxm package, see Marshalling XML using O/X Mappers.spring-doc.cn
