This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Type Conversion
By default, formatters for various number and date types are installed, along with support
for customization via @NumberFormat
and @DateTimeFormat
on fields and parameters.
To register custom formatters and converters in Java config, use the following:
Java
Kotlin
@EnableWebMvc
public void addFormatters(FormatterRegistry registry) {
@EnableWebMvc
override fun addFormatters(registry: FormatterRegistry) {
To do the same in XML config, use the following:
xmlns:mvc="http://www.springframework.org/schema/mvc"
xsi:schemaLocation="
https://www.springframework.org/schema/mvc/spring-mvc.xsd">
<mvc:annotation-driven conversion-service="conversionService"/>
<bean id="conversionService"
class="org.springframework.format.support.FormattingConversionServiceFactoryBean">
<property name="converters">
<set>
<bean class="org.example.MyConverter"/>
</set>
</property>
<property name="formatters">
<set>
<bean class="org.example.MyFormatter"/>
<bean class="org.example.MyAnnotationFormatterFactory"/>
</set>
</property>
<property name="formatterRegistrars">
<set>
<bean class="org.example.MyFormatterRegistrar"/>
</set>
</property>
</bean>
</beans>
By default Spring MVC considers the request Locale when parsing and formatting date values. This works for forms where dates are represented as Strings with "input" form fields. For "date" and "time" form fields, however, browsers use a fixed format defined in the HTML spec. For such cases date and time formatting can be customized as follows:
Java
Kotlin
@EnableWebMvc
DateTimeFormatterRegistrar registrar = new DateTimeFormatterRegistrar();
registrar.setUseIsoFormat(true);
registrar.registerFormatters(registry);
@EnableWebMvc
val registrar = DateTimeFormatterRegistrar()
See the FormatterRegistrar SPI
and the FormattingConversionServiceFactoryBean for more information on when to use
FormatterRegistrar implementations.
