This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Proxying Mechanisms
Spring AOP uses either JDK dynamic proxies or CGLIB to create the proxy for a given target object. JDK dynamic proxies are built into the JDK, whereas CGLIB is a common open-source class definition library (repackaged into spring-core).spring-doc.cn
If the target object to be proxied implements at least one interface, a JDK dynamic proxy is used. All of the interfaces implemented by the target type are proxied. If the target object does not implement any interfaces, a CGLIB proxy is created.spring-doc.cn
If you want to force the use of CGLIB proxying (for example, to proxy every method defined for the target object, not only those implemented by its interfaces), you can do so. However, you should consider the following issues:spring-doc.cn
  • With CGLIB, final methods cannot be advised, as they cannot be overridden in runtime-generated subclasses.spring-doc.cn
  • As of Spring 4.0, the constructor of your proxied object is NOT called twice anymore, since the CGLIB proxy instance is created through Objenesis. Only if your JVM does not allow for constructor bypassing, you might see double invocations and corresponding debug log entries from Spring’s AOP support.spring-doc.cn
  • Your CGLIB proxy usage may face limitations with the JDK 9+ platform module system. As a typical case, you cannot create a CGLIB proxy for a class from the java.lang package when deploying on the module path. Such cases require a JVM bootstrap flag --add-opens=java.base/java.lang=ALL-UNNAMED which is not available for modules.spring-doc.cn
To force the use of CGLIB proxies, set the value of the proxy-target-class attribute of the <aop:config> element to true, as follows:spring-doc.cn
<aop:config proxy-target-class="true">
	<!-- other beans defined here... -->
</aop:config>
To force CGLIB proxying when you use the @AspectJ auto-proxy support, set the proxy-target-class attribute of the <aop:aspectj-autoproxy> element to true, as follows:spring-doc.cn
<aop:aspectj-autoproxy proxy-target-class="true"/>
Multiple <aop:config/> sections are collapsed into a single unified auto-proxy creator at runtime, which applies the strongest proxy settings that any of the <aop:config/> sections (typically from different XML bean definition files) specified. This also applies to the <tx:annotation-driven/> and <aop:aspectj-autoproxy/> elements.spring-doc.cn
To be clear, using proxy-target-class="true" on <tx:annotation-driven/>, <aop:aspectj-autoproxy/>, or <aop:config/> elements forces the use of CGLIB proxies for all three of them.spring-doc.cn
Understanding AOP Proxies
Spring AOP is proxy-based. It is vitally important that you grasp the semantics of what that last statement actually means before you write your own aspects or use any of the Spring AOP-based aspects supplied with the Spring Framework.spring-doc.cn
Consider first the scenario where you have a plain-vanilla, un-proxied, nothing-special-about-it, straight object reference, as the following code snippet shows:spring-doc.cn
public class SimplePojo implements Pojo {
	public void foo() {
		// this next method invocation is a direct call on the 'this' reference
		this.bar();
	public void bar() {
		// some logic...
class SimplePojo : Pojo {
	fun foo() {
		this.bar()
	fun bar() {
		// some logic...
If you invoke a method on an object reference, the method is invoked directly on that object reference, as the following image and listing show:spring-doc.cn
aop proxy plain pojo call
public class Main {
		Pojo pojo = new SimplePojo();
		// this is a direct method call on the 'pojo' reference
		pojo.foo();
fun main() {
	val pojo = SimplePojo()
	pojo.foo()
Things change slightly when the reference that client code has is a proxy. Consider the following diagram and code snippet:spring-doc.cn
aop proxy call
public class Main {
		ProxyFactory factory = new ProxyFactory(new SimplePojo());
		factory.addInterface(Pojo.class);
		factory.addAdvice(new RetryAdvice());
		Pojo pojo = (Pojo) factory.getProxy();
		// this is a method call on the proxy!
		pojo.foo();
fun main() {
	val factory = ProxyFactory(SimplePojo())
	factory.addInterface(Pojo::class.java)
	factory.addAdvice(RetryAdvice())
	val pojo = factory.proxy as Pojo
	pojo.foo()
The key thing to understand here is that the client code inside the main(..) method of the Main class has a reference to the proxy. This means that method calls on that object reference are calls on the proxy. As a result, the proxy can delegate to all of the interceptors (advice) that are relevant to that particular method call. However, once the call has finally reached the target object (the SimplePojo reference in this case), any method calls that it may make on itself, such as this.bar() or this.foo(), are going to be invoked against the this reference, and not the proxy. This has important implications. It means that self-invocation is not going to result in the advice associated with a method invocation getting a chance to run.spring-doc.cn
Okay, so what is to be done about this? The best approach (the term "best" is used loosely here) is to refactor your code such that the self-invocation does not happen. This does entail some work on your part, but it is the best, least-invasive approach. The next approach is absolutely horrendous, and we hesitate to point it out, precisely because it is so horrendous. You can (painful as it is to us) totally tie the logic within your class to Spring AOP, as the following example shows:spring-doc.cn
	public void foo() {
		// this works, but... gah!
		((Pojo) AopContext.currentProxy()).bar();
	public void bar() {
		// some logic...
	fun foo() {
		(AopContext.currentProxy() as Pojo).bar()
	fun bar() {
		// some logic...
This totally couples your code to Spring AOP, and it makes the class itself aware of the fact that it is being used in an AOP context, which flies in the face of AOP. It also requires some additional configuration when the proxy is being created, as the following example shows:spring-doc.cn
public class Main {
		factory.setExposeProxy(true);
		pojo.foo();
fun main() {
	factory.isExposeProxy = true
	pojo.foo()
Finally, it must be noted that AspectJ does not have this self-invocation issue because it is not a proxy-based AOP framework.spring-doc.cn
