This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
MVC Config
The MVC Java configuration and the MVC XML namespace provide default configuration suitable for most applications and a configuration API to customize it.
For more advanced customizations, which are not available in the configuration API, see Advanced Java Config and Advanced XML Config.
You do not need to understand the underlying beans created by the MVC Java configuration and the MVC namespace. If you want to learn more, see Special Bean Types and Web MVC Config.
