This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Functions
You can extend SpEL by registering user-defined functions that can be called within
expressions by using the #functionName(…)
syntax. Functions can be registered as
variables in EvaluationContext
implementations via the setVariable()
method.
Since functions share a common namespace with variables in the evaluation context, care must be taken to ensure that function names and variable names do not overlap. |
The following example shows how to register a user-defined function to be invoked via
reflection using a java.lang.reflect.Method
Java
Kotlin
Method method = ...;
EvaluationContext context = SimpleEvaluationContext.forReadOnlyDataBinding().build();
context.setVariable("myFunction", method);
val method: Method = ...
val context = SimpleEvaluationContext.forReadOnlyDataBinding().build()
For example, consider the following utility method that reverses a string:
Java
Kotlin
public abstract class StringUtils {
public static String reverseString(String input) {
return new StringBuilder(input).reverse().toString();
fun reverseString(input: String): String {
return StringBuilder(input).reverse().toString()
You can register and use the preceding method, as the following example shows:
Java
Kotlin
ExpressionParser parser = new SpelExpressionParser();
context.setVariable("reverseString",
StringUtils.class.getMethod("reverseString", String.class));
// evaluates to "olleh"
String helloWorldReversed = parser.parseExpression(
"#reverseString('hello')").getValue(context, String.class);
val parser = SpelExpressionParser()
context.setVariable("reverseString", ::reverseString.javaMethod)
val helloWorldReversed = parser.parseExpression(
"#reverseString('hello')").getValue(context, String::class.java)
A function can also be registered as a java.lang.invoke.MethodHandle
. This enables
potentially more efficient use cases if the MethodHandle
target and parameters have
been fully bound prior to registration; however, partially bound handles are also
supported.
Consider the String#formatted(Object…)
instance method, which produces a message
according to a template and a variable number of arguments.
You can register and use the formatted
method as a MethodHandle
, as the following
example shows:
Java
Kotlin
MethodHandle mh = MethodHandles.lookup().findVirtual(String.class, "formatted",
MethodType.methodType(String.class, Object[].class));
context.setVariable("message", mh);
// evaluates to "Simple message: <Hello World>"
String message = parser.parseExpression("#message('Simple message: <%s>', 'Hello World', 'ignored')")
val mh = MethodHandles.lookup().findVirtual(String::class.java, "formatted",
MethodType.methodType(String::class.java, Array<Any>::class.java))
val message = parser.parseExpression("#message('Simple message: <%s>', 'Hello World', 'ignored')")
As mentioned above, binding a MethodHandle
and registering the bound MethodHandle
is
also supported. This is likely to be more performant if both the target and all the
arguments are bound. In that case no arguments are necessary in the SpEL expression, as
Java
Kotlin
String template = "This is a %s message with %s words: <%s>";
Object varargs = new Object[] { "prerecorded", 3, "Oh Hello World!", "ignored" };
.bindTo(template)
// Here we have to provide the arguments in a single array binding:
.bindTo(varargs);
// evaluates to "This is a prerecorded message with 3 words: <Oh Hello World!>"
String message = parser.parseExpression("#message()")
val template = "This is a %s message with %s words: <%s>"
val varargs = arrayOf("prerecorded", 3, "Oh Hello World!", "ignored")
.bindTo(template)
.bindTo(varargs)
val message = parser.parseExpression("#message()")
