This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Requirements
Spring Framework supports Kotlin 1.7+ and requires
kotlin-stdlib
and kotlin-reflect
to be present on the classpath. They are provided by default if you bootstrap a Kotlin project on
start.spring.io.
The Jackson Kotlin module is required
for serializing or deserializing JSON data for Kotlin classes with Jackson, so make sure to add the
com.fasterxml.jackson.module:jackson-module-kotlin dependency to your project if you have such need.
It is automatically registered when found in the classpath.
