This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Context Configuration Inheritance
@ContextConfiguration
supports boolean inheritLocations
and inheritInitializers
attributes that denote whether resource locations or component classes and context
initializers declared by superclasses should be inherited. The default value for both
flags is true
. This means that a test class inherits the resource locations or
component classes as well as the context initializers declared by any superclasses.
Specifically, the resource locations or component classes for a test class are appended
to the list of resource locations or annotated classes declared by superclasses.
Similarly, the initializers for a given test class are added to the set of initializers
defined by test superclasses. Thus, subclasses have the option of extending the resource
locations, component classes, or context initializers.
If the inheritLocations
or inheritInitializers
attribute in @ContextConfiguration
is set to false
, the resource locations or component classes and the context
initializers, respectively, for the test class shadow and effectively replace the
configuration defined by superclasses.
As of Spring Framework 5.3, test configuration may also be inherited from enclosing
classes. See @Nested test class configuration for details.
In the next example, which uses XML resource locations, the ApplicationContext
for
ExtendedTest
is loaded from base-config.xml
and extended-config.xml
, in that order.
Beans defined in extended-config.xml
can, therefore, override (that is, replace) those
defined in base-config.xml
. The following example shows how one class can extend
another and use both its own configuration file and the superclass’s configuration file:
Java
Kotlin
@ExtendWith(SpringExtension.class)
// ApplicationContext will be loaded from "/base-config.xml"
// in the root of the classpath
@ContextConfiguration("/base-config.xml") (1)
class BaseTest {
// class body...
// ApplicationContext will be loaded from "/base-config.xml" and
// "/extended-config.xml" in the root of the classpath
@ContextConfiguration("/extended-config.xml") (2)
class ExtendedTest extends BaseTest {
// class body...
1 | Configuration file defined in the superclass. |
2 | Configuration file defined in the subclass. |
@ExtendWith(SpringExtension::class)
open class BaseTest {
// class body...
class ExtendedTest : BaseTest() {
// class body...
Similarly, in the next example, which uses component classes, the ApplicationContext
for ExtendedTest
is loaded from the BaseConfig
and ExtendedConfig
classes, in that
order. Beans defined in ExtendedConfig
those defined in BaseConfig
another and use both its own configuration class and the superclass’s configuration class:
Java
Kotlin
// ApplicationContext will be loaded from BaseConfig
@SpringJUnitConfig(BaseConfig.class) (1)
class BaseTest {
// class body...
// ApplicationContext will be loaded from BaseConfig and ExtendedConfig
@SpringJUnitConfig(ExtendedConfig.class) (2)
// class body...
1 | Configuration class defined in the superclass. |
2 | Configuration class defined in the subclass. |
@SpringJUnitConfig(BaseConfig::class) (1)
// class body...
@SpringJUnitConfig(ExtendedConfig::class) (2)
// class body...
In the next example, which uses context initializers, the ApplicationContext
for
ExtendedTest
is initialized by using BaseInitializer
and ExtendedInitializer
. Note,
however, that the order in which the initializers are invoked depends on whether they
implement Spring’s Ordered
interface or are annotated with Spring’s @Order
annotation
or the standard @Priority
annotation. The following example shows how one class can
extend another and use both its own initializer and the superclass’s initializer:
Java
Kotlin
// ApplicationContext will be initialized by BaseInitializer
@SpringJUnitConfig(initializers = BaseInitializer.class) (1)
class BaseTest {
// class body...
// and ExtendedInitializer
@SpringJUnitConfig(initializers = ExtendedInitializer.class) (2)
// class body...
1 | Initializer defined in the superclass. |
2 | Initializer defined in the subclass. |
@SpringJUnitConfig(initializers = [BaseInitializer::class]) (1)
// class body...
@SpringJUnitConfig(initializers = [ExtendedInitializer::class]) (2)
// class body...
