This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Introductions
Introductions (known as inter-type declarations in AspectJ) enable an aspect to declare that advised objects implement a given interface, and to provide an implementation of that interface on behalf of those objects.
You can make an introduction by using the @DeclareParents
annotation. This annotation
is used to declare that matching types have a new parent (hence the name). For example,
given an interface named UsageTracked
and an implementation of that interface named
DefaultUsageTracked
, the following aspect declares that all implementors of service
interfaces also implement the UsageTracked
interface (e.g. for statistics via JMX):
Java
Kotlin
@Aspect
public class UsageTracking {
@DeclareParents(value="com.xyz.service.*+", defaultImpl=DefaultUsageTracked.class)
public static UsageTracked mixin;
@Before("execution(* com.xyz..service.*.*(..)) && this(usageTracked)")
public void recordUsage(UsageTracked usageTracked) {
usageTracked.incrementUseCount();
@Aspect
companion object {
@DeclareParents(value = "com.xyz.service.*+",
defaultImpl = DefaultUsageTracked::class)
lateinit var mixin: UsageTracked
fun recordUsage(usageTracked: UsageTracked) {
The interface to be implemented is determined by the type of the annotated field. The
value
attribute of the @DeclareParents
annotation is an AspectJ type pattern. Any
bean of a matching type implements the UsageTracked
interface. Note that, in the
before advice of the preceding example, service beans can be directly used as
implementations of the UsageTracked
interface. If accessing a bean programmatically,
you would write the following:
Java
Kotlin
UsageTracked usageTracked = context.getBean("myService", UsageTracked.class);
val usageTracked = context.getBean("myService", UsageTracked.class)
