This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
Using Generics as Autowiring Qualifiers
In addition to the @Qualifier annotation, you can use Java generic types as an implicit form of qualification. For example, suppose you have the following configuration:spring-doc.cn
public class MyConfiguration {
	public StringStore stringStore() {
		return new StringStore();
	public IntegerStore integerStore() {
		return new IntegerStore();
	fun stringStore() = StringStore()
	fun integerStore() = IntegerStore()
Assuming that the preceding beans implement a generic interface, (that is, Store<String> and Store<Integer>), you can @Autowire the Store interface and the generic is used as a qualifier, as the following example shows:spring-doc.cn
@Autowired
private Store<String> s1; // <String> qualifier, injects the stringStore bean
@Autowired
private Store<Integer> s2; // <Integer> qualifier, injects the integerStore bean
@Autowired
private lateinit var s1: Store<String> // <String> qualifier, injects the stringStore bean
@Autowired
private lateinit var s2: Store<Integer> // <Integer> qualifier, injects the integerStore bean
Generic qualifiers also apply when autowiring lists, Map instances and arrays. The following example autowires a generic List:spring-doc.cn
// Inject all Store beans as long as they have an <Integer> generic
// Store<String> beans will not appear in this list
@Autowired
private List<Store<Integer>> s;
@Autowired
private lateinit var s: List<Store<Integer>>
