This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
HtmlUnit Integration
Spring provides integration between MockMvc and HtmlUnit. This simplifies performing end-to-end testing when using HTML-based views. This integration lets you:
Easily test HTML pages by using tools such as HtmlUnit, WebDriver, and Geb without the need to deploy to a Servlet container.
Test JavaScript within pages.
Optionally, test using mock services to speed up testing.
Share logic between in-container end-to-end tests and out-of-container integration tests.
MockMvc works with templating technologies that do not rely on a Servlet Container (for example, Thymeleaf, FreeMarker, and others), but it does not work with JSPs, since they rely on the Servlet container. |
