This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Servlet Config
In a Servlet environment, you have the option of configuring the Servlet container
programmatically as an alternative or in combination with a web.xml
file.
The following example registers a DispatcherServlet
Java
Kotlin
import org.springframework.web.WebApplicationInitializer;
public class MyWebApplicationInitializer implements WebApplicationInitializer {
public void onStartup(ServletContext container) {
XmlWebApplicationContext appContext = new XmlWebApplicationContext();
appContext.setConfigLocation("/WEB-INF/spring/dispatcher-config.xml");
ServletRegistration.Dynamic registration = container.addServlet("dispatcher", new DispatcherServlet(appContext));
registration.setLoadOnStartup(1);
registration.addMapping("/");
class MyWebApplicationInitializer : WebApplicationInitializer {
override fun onStartup(container: ServletContext) {
val appContext = XmlWebApplicationContext()
val registration = container.addServlet("dispatcher", DispatcherServlet(appContext))
is an interface provided by Spring MVC that ensures your
implementation is detected and automatically used to initialize any Servlet 3 container.
An abstract base class implementation of WebApplicationInitializer
named
AbstractDispatcherServletInitializer
makes it even easier to register the
DispatcherServlet
by overriding methods to specify the servlet mapping and the
location of the DispatcherServlet
configuration.
This is recommended for applications that use Java-based Spring configuration, as the following example shows:
Java
Kotlin
public class MyWebAppInitializer extends AbstractAnnotationConfigDispatcherServletInitializer {
protected Class<?>[] getRootConfigClasses() {
return null;
protected Class<?>[] getServletConfigClasses() {
return new Class<?>[] { MyWebConfig.class };
protected String[] getServletMappings() {
return new String[] { "/" };
class MyWebAppInitializer : AbstractAnnotationConfigDispatcherServletInitializer() {
override fun getRootConfigClasses(): Array<Class<*>>? {
return null
override fun getServletConfigClasses(): Array<Class<*>>? {
return arrayOf(MyWebConfig::class.java)
override fun getServletMappings(): Array<String> {
return arrayOf("/")
If you use XML-based Spring configuration, you should extend directly from
Java
Kotlin
public class MyWebAppInitializer extends AbstractDispatcherServletInitializer {
protected WebApplicationContext createRootApplicationContext() {
return null;
protected WebApplicationContext createServletApplicationContext() {
XmlWebApplicationContext cxt = new XmlWebApplicationContext();
cxt.setConfigLocation("/WEB-INF/spring/dispatcher-config.xml");
return cxt;
class MyWebAppInitializer : AbstractDispatcherServletInitializer() {
override fun createRootApplicationContext(): WebApplicationContext? {
return null
override fun createServletApplicationContext(): WebApplicationContext {
return XmlWebApplicationContext().apply {
return arrayOf("/")
also provides a convenient way to add Filter
instances and have them be automatically mapped to the DispatcherServlet
, as the
Java
Kotlin
protected Filter[] getServletFilters() {
return new Filter[] {
new HiddenHttpMethodFilter(), new CharacterEncodingFilter() };
override fun getServletFilters(): Array<Filter> {
return arrayOf(HiddenHttpMethodFilter(), CharacterEncodingFilter())
Each filter is added with a default name based on its concrete type and automatically
The isAsyncSupported
protected method of AbstractDispatcherServletInitializer
provides a single place to enable async support on the DispatcherServlet
and all
filters mapped to it. By default, this flag is set to true
Finally, if you need to further customize the DispatcherServlet
itself, you can
override the createDispatcherServlet
method.
