This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
PDF and Excel
Spring offers ways to return output other than HTML, including PDF and Excel spreadsheets. This section describes how to use those features.
Introduction to Document Views
An HTML page is not always the best way for the user to view the model output, and Spring makes it simple to generate a PDF document or an Excel spreadsheet dynamically from the model data. The document is the view and is streamed from the server with the correct content type, to (hopefully) enable the client PC to run their spreadsheet or PDF viewer application in response.
In order to use Excel views, you need to add the Apache POI library to your classpath. For PDF generation, you need to add (preferably) the OpenPDF library.
You should use the latest versions of the underlying document-generation libraries, if possible. In particular, we strongly recommend OpenPDF (for example, OpenPDF 1.2.12) instead of the outdated original iText 2.1.7, since OpenPDF is actively maintained and fixes an important vulnerability for untrusted PDF content. |
PDF Views
A simple PDF view for a word list could extend
org.springframework.web.servlet.view.document.AbstractPdfView
and implement the
buildPdfDocument()
method, as the following example shows:
Java
Kotlin
public class PdfWordList extends AbstractPdfView {
protected void buildPdfDocument(Map<String, Object> model, Document doc, PdfWriter writer,
HttpServletRequest request, HttpServletResponse response) throws Exception {
List<String> words = (List<String>) model.get("wordList");
for (String word : words) {
doc.add(new Paragraph(word));
class PdfWordList : AbstractPdfView() {
override fun buildPdfDocument(model: Map<String, Any>, doc: Document, writer: PdfWriter,
request: HttpServletRequest, response: HttpServletResponse) {
val words = model["wordList"] as List<String>
for (word in words) {
doc.add(Paragraph(word))
A controller can return such a view either from an external view definition
(referencing it by name) or as a View
instance from the handler method.
Excel Views
Since Spring Framework 4.2,
org.springframework.web.servlet.view.document.AbstractXlsView
is provided as a base
class for Excel views. It is based on Apache POI, with specialized subclasses (AbstractXlsxView
and AbstractXlsxStreamingView
) that supersede the outdated AbstractExcelView
class.
The programming model is similar to AbstractPdfView
, with buildExcelDocument()
as the central template method and controllers being able to return such a view from
an external definition (by name) or as a View
