This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
Connecting to a Broker
A STOMP broker relay maintains a single “system” TCP connection to the broker.
This connection is used for messages originating from the server-side application
only, not for receiving messages. You can configure the STOMP credentials (that is,
the STOMP frame login
and passcode
headers) for this connection. This is exposed
in both the XML namespace and Java configuration as the systemLogin
and
systemPasscode
properties with default values of guest
and guest
The STOMP broker relay also creates a separate TCP connection for every connected
WebSocket client. You can configure the STOMP credentials that are used for all TCP
connections created on behalf of clients. This is exposed in both the XML namespace
and Java configuration as the clientLogin
and clientPasscode
values of guest
and guest
The STOMP broker relay always sets the login and passcode headers on every CONNECT
frame that it forwards to the broker on behalf of clients. Therefore, WebSocket clients
need not set those headers. They are ignored. As the Authentication
section explains, WebSocket clients should instead rely on HTTP authentication to protect
the WebSocket endpoint and establish the client identity.
The STOMP broker relay also sends and receives heartbeats to and from the message broker over the “system” TCP connection. You can configure the intervals for sending and receiving heartbeats (10 seconds each by default). If connectivity to the broker is lost, the broker relay continues to try to reconnect, every 5 seconds, until it succeeds.
Any Spring bean can implement ApplicationListener<BrokerAvailabilityEvent>
to receive notifications when the “system” connection to the broker is lost and
re-established. For example, a Stock Quote service that broadcasts stock quotes can
stop trying to send messages when there is no active “system” connection.
By default, the STOMP broker relay always connects, and reconnects as needed if connectivity is lost, to the same host and port. If you wish to supply multiple addresses, on each attempt to connect, you can configure a supplier of addresses, instead of a fixed host and port. The following example shows how to do that:
@EnableWebSocketMessageBroker
public class WebSocketConfig extends AbstractWebSocketMessageBrokerConfigurer {
public void configureMessageBroker(MessageBrokerRegistry registry) {
registry.enableStompBrokerRelay("/queue/", "/topic/").setTcpClient(createTcpClient());
registry.setApplicationDestinationPrefixes("/app");
private ReactorNettyTcpClient<byte[]> createTcpClient() {
return new ReactorNettyTcpClient<>(
client -> client.addressSupplier(() -> ... ),
new StompReactorNettyCodec());
You can also configure the STOMP broker relay with a virtualHost
property.
The value of this property is set as the host
header of every CONNECT
frame
and can be useful (for example, in a cloud environment where the actual host to which
the TCP connection is established differs from the host that provides the
cloud-based STOMP service).
