This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4!spring-doc.cn
@SessionAttributes
@SessionAttributes is used to store model attributes in the WebSession between requests. It is a type-level annotation that declares session attributes used by a specific controller. This typically lists the names of model attributes or types of model attributes that should be transparently stored in the session for subsequent requests to access.spring-doc.cn
Consider the following example:spring-doc.cn
@Controller
@SessionAttributes("pet") (1)
public class EditPetForm {
1 Using the @SessionAttributes annotation.
@Controller
class EditPetForm {
On the first request, when a model attribute with the name, pet, is added to the model, it is automatically promoted to and saved in the WebSession. It remains there until another controller method uses a SessionStatus method argument to clear the storage, as the following example shows:spring-doc.cn
@Controller
	@PostMapping("/pets/{id}")
	public String handle(Pet pet, BindingResult errors, SessionStatus status) { (2)
		if (errors.hasErrors()) {
			status.setComplete();
2 Using a SessionStatus variable.
@Controller
class EditPetForm {
	fun handle(pet: Pet, errors: BindingResult, status: SessionStatus): String { (2)
