This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.4! |
@SqlConfig
@SqlConfig
defines metadata that is used to determine how to parse and run SQL scripts
configured with the @Sql
annotation. The following example shows how to use it:
Java
Kotlin
@Test
@Sql(
scripts = "/test-user-data.sql",
config = @SqlConfig(commentPrefix = "`", separator = "@@") (1)
void userTest() {
// run code that relies on the test data
1 | Set the comment prefix and the separator in SQL scripts. |
@Test
@Sql("/test-user-data.sql", config = SqlConfig(commentPrefix = "`", separator = "@@")) (1)
fun userTest() {
